Help Identify a Tach, Used Tach from 914? |
dcsan13 |
Feb 12 2017, 09:18 AM
I'm new here ... Group: Members Posts: 0 Joined: 20-April 13 From: Washington, DC Member No.: 15,787 Region Association: North East States |
I acquired this Tach with quite a few 914 parts a few years ago.
Can anyone help identify what it fits or works with? There are no numbers on the housing that I could find. I appreciate any help. Attached thumbnail(s) |
bdstone914 |
Feb 12 2017, 09:24 AM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Late 74-76 tach. Interesting that the red line mark is missing. Must be for an engine with no rev limit. (IMG:style_emoticons/default/av-943.gif)
Note the ink stamp on the back indicating 1/74 date. Will work on any year 914 but is the non silver dot type. Might be a custom face as there is no turn signal light indicator at the top. If you look up in the inside at the 12 O'clock position it will have the part number. Attached thumbnail(s) |
Chris914n6 |
Feb 13 2017, 01:23 AM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Also an 8k rpm mark. Mine only goes to 7.
Kinda funky, not the standard face... |
dcsan13 |
Aug 27 2017, 06:16 PM
Late 74-76 tach. Interesting that the red line mark is missing. Must be for an engine with no rev limit. (IMG:style_emoticons/default/av-943.gif) Note the ink stamp on the back indicating 1/74 date. Will work on any year 914 but is the non silver dot type. Might be a custom face as there is no turn signal light indicator at the top. If you look up in the inside at the 12 O'clock position it will have the part number. Dern!!! I just saw your reply and I appreciate the help! Thanks very much, David |
dcsan13 |
Aug 27 2017, 06:18 PM
PancakePorsche |
Aug 27 2017, 10:17 PM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
1974-1976 tachs had single turn indicator, no arrows. Gotta be a re-faced 911 unit.
Lo-Fi Version | Time is now: 1st June 2024 - 08:26 PM |
