Spacers for rear of car, 17x9s 245/40/17 |
tazz9924 |
Feb 26 2017, 10:24 AM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
I bought a set of euromiester fuchs fro the rear of my fiberglass flared 914. im running 245/40/17s tires. how much spacer do i need?
sixnotfour |
Feb 26 2017, 11:30 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
what is the offset ??
jmill |
Feb 26 2017, 11:44 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Fiberglass flares may give you more room than steel. It might be best to remove springs while car is in the air. Slide washers on the wheel studs until the tire sits just right in the fender when the control arm is jacked up to your desired ride height. Do it on both sides in case they are different. Measure the washer stack and buy a set of spacers equal or closest to the small side.
tazz9924 |
Feb 26 2017, 12:01 PM
sixnotfour |
Feb 26 2017, 12:24 PM
then they are like 9x16s and will fit fine. as stated above you can space them per your personal taste to define the look your after
Lo-Fi Version | Time is now: 10th June 2024 - 01:10 AM |
