> Adjusting Fuel Pressure for Better Running Engine, 1.7 Engine Performance
R Shaff
post Mar 28 2017, 05:06 AM
I've read some helpful things here while helping with my brother's '72 914. I think I've learned something new and thought I'd share it with you guys.
This car has the original engine and FI system, though the ignition system has been updated and is electronic. The car wasn't running well, and the local shop my brother uses said he should do a carb conversion, costing over $4,000. We looked online and found some good write-ups that recommended keeping the FI system. I've worked on many cars and restored one, so I thought I'd try to get the car running well enough with the original system.
The compression and ignition checked out fine. We adjusted the valves (of course). We tested and then replaced 3 injectors, and the CHT sensor. I put the fuel pressure at 28 psi, per spec. Static tests of the manifold pressure sensor came out fine. A cigar smoke test showed no intake leaks. We cleaned and adjusted the TPS, and then finally changed the TPS contact plate and adjusted the arm (when the car just wouldn't run right). All the other components checked out fine, using tests I found online.
The result? The engine fired right up, with a good idle. But when driving it lacked power, and the higher the rpm the less it wanted to pull. (Not right for a Porsche.) It felt like the timing wasn't advancing, or that the engine just wasn't getting enough air or gas in the right balance.
Other than buying a replacement MPS or computer, I was running out of ideas to try. One of good things about carbs is that they are adjustable. One of the challenging things about these old open-loop FI systems is that they are not really designed to be adjusted much, or at all. Repair is usually a process of testing and replacing components. But this car sure felt like it needed some kind of adjustment.
One of the odd things about this car, in my experience, is that the fuel pressure regulator IS adjustable. So that's what we tried, just using seat-of-the-pants performance as the indicator. We dialed the pressure down a turn and things got worse. Then we turned the pressure up, one turn at a time, and voila! As we did the car ran better and better. Now it pulls in the upper ranges like it should, much like it used to.
Now we're going to buy a 4th injector of the same type and adjust the pressure again as needed. (Now that we know we can adjust the whole system.) Perhaps that will make it run better still.
I haven't read that anywhere(about adjusting fuel pressure to get the engine to run better) so I thought it might help someone else who is struggling with these old Bosch systems.
Happy motoring!
Richard
Replies(1 - 19)
Minerva's 914
post Mar 28 2017, 08:21 AM
Thanks Richard for the writeup. When Fat Performance built my 2.0L motor with a slight (80cc) increase in displacement, they suggested that I might need to increase the fuel pressure to get the most out of the motor but I couldn't find any reference to anyone doing this, so I was a bit unsure if I would benefit from do it and no longer having a FPG to read the pressure unnerved at shooting in the dark.
So, let me ask a question. Would I be correct in guessing that looking down on the adjustment screw turning clockwise (screwing in) would reduce pressure and turning counterclockwise (screwing out) would increase pressure?
Thanks again mate, and (IMG:style_emoticons/default/welcome.png)
Brady
R Shaff
post Mar 28 2017, 08:48 AM
QUOTE(Minerva's 914 @ Mar 28 2017, 10:21 AM) *
Brady
Brady,
I found the opposite to be the case. Once you have loosened the locking nut buy a few threads (13mm nut, I think), then you turn the bolt in, clockwise, to increase pressure, and out to decrease pressure.
I had a pressure gauge on it when I first made the adjustment. It wasn't real sensitive to small turns. When I made adjustments this time, I did it in whole turn (360 degree) increments (corresponding to a thread on the bolt).
And of course, one needs to re-tighten the locking nut when done.
(Ive read that one can make small mixture adjustments with the knob on the ECU, which I have not tried yet. But those adjustments are supposed to only affect the mixture at idle. Not sure about that, but I'll try it too.)
I hope that helps.
boxsterfan
post Mar 28 2017, 12:08 PM
914's are kewl
Did you clean your distributor? And put of drop of oil ont eh advance plates?
914sgofast2
post Mar 28 2017, 12:11 PM
I agree that adjusting the fuel pressure works. After I rebuilt my son's 1.7,I checked the fuel pressure. It was 28# so I increased it to30# by adjusting the pressure regulator. Now that baby really screams! It's an early 1970 model year, so there is no adjustment knob on the computer unit.
R Shaff
post Mar 28 2017, 12:15 PM
QUOTE(boxsterfan @ Mar 28 2017, 02:08 PM) *
Thanks. You're right. I should do that too. The timing on this model is set at a higher rpm (2000 or so if I remember right), and we did that. But timing could still be an issue at upper rpms.
mark04usa
post Mar 28 2017, 01:25 PM
'70 1.7 Tangerine
Timing set at 27 deg advance (with vac lines disconnected) at 3,500 RPM
jim_hoyland
post Mar 28 2017, 01:26 PM
Get that VIN ?
Several years ago a local gave me a ride in his '74 L-Jet; it screamed like no stock 914
He had increased FP to 43#, adjusted the WOT at the AFM, and reamed out the TB
Felt like a -6; stock P&Cs to boot
914_teener
post Mar 28 2017, 04:47 PM
QUOTE(914sgofast2 @ Mar 28 2017, 11:11 AM) *
The adjustment knob on the later ecu.s only affects the idle circuit and not the injector pulse duration.
R Shaff
post Mar 28 2017, 05:12 PM
QUOTE(mark04usa @ Mar 28 2017, 03:25 PM) *
THX. I remember now. That's what we did. Though it was a first for me, to set (or rather to check) timing at that high rpm. One of the benefits of electronic ignition was that it didn't need to be adjusted.
Minerva's 914
post Mar 28 2017, 05:18 PM
QUOTE(R Shaff @ Mar 28 2017, 10:48 AM) *
Brady
Brady,
I hope that helps.
Sweet! Exactly what I needed to hear. Right now I'm only about 20 miles into the break-in so I'll not be running it to high revs until I do the 1,000 mile oil change and valve adjustment but may start playing with the FP a little bit here. I would think the real value of an increase in FP would be at higher RPMs as the demands on fuel delivery increases so the real tale of the tape will come later.
Man this 914 stuff is fun! Might have to get another one!
PancakePorsche
post Mar 28 2017, 10:57 PM
With all the alcohol in what they call gas, you need to increase volume by 10% I agree with the fuel pressure @32 PSI made my 2.0 run like a champ and lowered temps.
jim_hoyland
post Mar 29 2017, 05:13 AM
Get that VIN ?
Am I correct ? Certain year Pressure Regulators at NOT adjustable ?
Minerva's 914
post Mar 29 2017, 08:32 PM
I need to buy a fuel pressure gauge. What model do you guys recommend? The choices I'm running across have mixed reviews and the prices are all over the place. (IMG:style_emoticons/default/confused24.gif)
r_towle
post Mar 29 2017, 09:09 PM
Custom Member
QUOTE(R Shaff @ Mar 28 2017, 02:15 PM) *
It is the problem.
They get sticky when hot, remove and replace the grease between the advance plates.
It's not a Porsche power band, it's vw.
You will feel power drop at 4800 rpms....that's all you get...
There are dyno charts here somewhere.
Clean the advance plates, you are almost done!
914_teener
post Mar 29 2017, 10:08 PM
QUOTE(Minerva's 914 @ Mar 29 2017, 07:32 PM) *
The one at HF works fine.
Minerva's 914
post Mar 30 2017, 04:36 AM
QUOTE(914_teener @ Mar 30 2017, 12:08 AM) *
By chance you have a link to buy it? (in other words, who's HF?)
Thx
BeatNavy
post Mar 30 2017, 05:28 AM
QUOTE(Minerva's 914 @ Mar 30 2017, 06:36 AM) *
HF = Harbor Freight. You can't be a card carrying CSOB 914 owner without knowing that.
http://www.harborfreight.com/fuel-injectio...ster-62623.html
Cheap stuff. In general , don't buy anything there you REALLY need to last or work well.
Minerva's 914
post Mar 30 2017, 12:42 PM
QUOTE(BeatNavy @ Mar 30 2017, 07:28 AM) *
So THAT's why my CSOB 914 Member card hasn't arrived yet! I been wondering 'bout that.
Thanks, I'll check it out.
R Shaff
post Mar 31 2017, 06:19 AM
OK. I'll check and prob clean the advance mechanism. Thanks.
Moving now from facts to personal opinions... I have a pressure gauge but I probably won't be using it for this anymore. For starters, it's a pain to do and usually gets some gas in the engine bay. Second, it's real easy to take a couple of wrenches with me, go for a test ride, and tweak the fuel pressure at stops along the way.
When making the mixture richer, with higher pressure, my plan is to take it only as far as it makes a noticeable difference. No further. And I plan to check the plugs relatively soon to make sure that setting isn't too rich overall.
Basically, I think every mechanism works best with some form of adjustment. The more complex the mechanism is, the more it needs it. None of these engines are new, and the components have unknown degrees function, misfunction, and variation. Modern closed-loop systems adjust for those variables constantly. These old cars are the opposite of that.
I don't know whether the engineers at VW/Porsche planned for the adjustable fuel pressure regulator to be used this way or not. (I suspect not). But for a car this old with this many variables, having an effective adjustment capability sure helps!
- Lo-Fi Version Time is now: 12th July 2025 - 10:56 AM
