WTB 71 1.7 valve covers |
mikesjunk |
Apr 1 2017, 04:23 PM
Member Group: Members Posts: 71 Joined: 29-November 15 From: goddard, KS Member No.: 19,423 Region Association: None |
Looking for a set or just one valve covers for a 71 1.7l. My drives side seems to be warped and I can't get it to stop leaking. The don't have to be pretty as I have a bead blaster...just need to be flat.
Also need a drivers side window regulator. Mine the wheel thing has popped off. Let me know what you have. Thanks! Mike |
euro911 |
Apr 1 2017, 05:27 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Looking for a set or just one valve covers for a 71 1.7l. My drives side seems to be warped and I can't get it to stop leaking. The don't have to be pretty as I have a bead blaster...just need to be flat. 914rubber sells a slightly thicker gasket ... stopped my leak (IMG:style_emoticons/default/idea.gif) Also need a drivers side window regulator. Mine the wheel thing has popped off. Let me know what you have. Thanks! Mike |
mikesjunk |
Apr 1 2017, 07:00 PM
Looking for a set or just one valve covers for a 71 1.7l. My drives side seems to be warped and I can't get it to stop leaking. The don't have to be pretty as I have a bead blaster...just need to be flat. 914rubber sells a slightly thicker gasket ... stopped my leak (IMG:style_emoticons/default/idea.gif)Also need a drivers side window regulator. Mine the wheel thing has popped off. Let me know what you have. Thanks! Mike Yes I have those, the silicone ones. Passenger side is spotless....not so much on divers. (IMG:style_emoticons/default/sad.gif) |
mikesjunk |
Apr 1 2017, 08:15 PM
Ok, got a regulator coming now so just need a valve cover.
TheCabinetmaker |
Apr 2 2017, 06:39 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Hey Mike, I have a cover for you. Pm sent
Lo-Fi Version | Time is now: 7th June 2024 - 09:22 PM |
