| StratPlayer |
Apr 3 2017, 05:09 PM
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,360 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains
How many here that flat tow their 914 bungee cord the steering wheel when towing the car?
| sb914 |
Apr 3 2017, 05:59 PM
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,616 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California
I thought you were supposed to leave free when flat towing.
The front wheels will turn accordingly. |
| StratPlayer |
Apr 3 2017, 06:35 PM
The bungee is considered a tool to complete your towing package. It is the right fix. Not a hack fix at all. It is a tool to center the wheel just like the towbar is a tool to tow the vehicle.
| 76-914 |
Apr 3 2017, 06:48 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Good question! (IMG:style_emoticons/default/popcorn[1].gif)
| Mikey914 |
Apr 3 2017, 06:56 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I don't. If you takeoff and the steering wheel starts gong back and forth. Stop. Align the wheels with the direction of travel and proceed. It happens when you take off and the wheels are not in the same direction as you are traveling. It oscillates back and forth. Easy to avoid.
| SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,462 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The bungee is considered a tool to complete your towing package. It is the right fix. Not a hack fix at all. It is a tool to center the wheel just like the towbar is a tool to tow the vehicle. If you have a good 4 wheel alignment, there is no need to artificially center the steering wheel. It will straighten itself out when running in a straight line. (IMG:style_emoticons/default/shades.gif) |
| Chris914n6 |
Apr 3 2017, 07:09 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,527 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
The bungee is to hold the wheel straightish in the event you HAVE to back up. Don't need it moving forward.
| Mikey914 |
Apr 3 2017, 07:12 PM
Haven't been able to back up very well. I always dropped the car off the ball and moved it. Did use a bungee chord to hold the bar up while I moved it around.
| VaccaRabite |
Apr 4 2017, 07:27 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,841 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Haven't been able to back up very well. I always dropped the car off the ball and moved it. Did use a bungee chord to hold the bar up while I moved it around. I keep a block of wood in the front trunk of my 914 for the job of holding up the tow bar. In my experience, if the car is aligned correctly there should be no wobble. If the car is out of alignment, all bets are off. Though if the car were out of alignment to the point where the wheels don't self center immediately, I'm not going to be flat towing it. The last thing I want is a bungie cord to break or slip on the free way and the tail to start wagging the dog. Zach |
| andys |
Apr 4 2017, 08:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
| Mikey914 |
Apr 4 2017, 09:08 AM
Haven't been able to back up very well. I always dropped the car off the ball and moved it. Did use a bungee chord to hold the bar up while I moved it around. I keep a block of wood in the front trunk of my 914 for the job of holding up the tow bar. In my experience, if the car is aligned correctly there should be no wobble. If the car is out of alignment, all bets are off. Though if the car were out of alignment to the point where the wheels don't self center immediately, I'm not going to be flat towing it. The last thing I want is a bungie cord to break or slip on the free way and the tail to start wagging the dog. Zach The dynamic oscillations would be VERY bad. Zach hit the nail on the head here. You are moving at freeway speeds, if the bungee breaks (and they occasionally do), do you really want the liability of an uncontrollable vehicle being towed at potentially high speed. Yes the odds are remote, but how lucky do you feel? If the bungee is needed to move forward, I'd re-think the process. |
| forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
I tow my car to and from my shop across town regularly while in the conversion process. I have no bungee cords in the tow kit. (and I am from Louisiana)..
My car tracks very well and is simply a matter of turning off the battery, turning the ignition key to the on position and releasing the emergency brake. The front wheels track perfectly behind the suv in all situations going forward. Even with a bungee cord, and a steering partner in the driver's seat, reverse is a no-no unless your ok with significant stress on the frame, tow hitch, and related connections. If you look closely, you can see the two 2"x2" hitch bar receivers cut-outs that are in the front bumper of my car. Black bumpers help here but basically, I built receiver tube-brackets that are bolted to the interior trunk frame of the car. The tow hitch bars slide in and each side has a 1/2" diameter drop-pin that keep everything connected and safely trailing along behind the tow vehicle that incidentally has heat and AC, Bose stereo, CD and Mp3 tunes, room to pack an ice chest and steamer trunk and most importantly, a happy wife in the passenger seat. (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th March 2026 - 07:23 AM |
