pgollender |
Member ![]() ![]() Group: Members Posts: 201 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California ![]() |
I have taken apart two 1970 W series motors and both had dome-top style pistons. Is the dome top still available as "new" or are all that are left are flat ones ?
I think the domes were rated at 8.2:1 compression ratio. The flat ones that I've seen are rated slightly less. If the original pistons themselves are in good shape what would you do ? Re-ring them or buy new flat stock with less compression ? Where are members gone for new cylinders ? Surely those old oxidized ones can't dissipate heat that effectively. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,194 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
All 1.7 Porsche had domed pistons and were 8:2:1. Flat top pistons where in the VW bus and VW 411. Do not know what is offered now. Every now and then a set of the OEM domed pistons show up for sale on Ebay or theSamba.com.
PancakePorsche |
Member ![]() ![]() Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None ![]() |
If they are within wear limit and no scuffing, do a light hone and re-ring. I did that to a GB code 2.0 with 8.5's and put on another 100K miles.
Lo-Fi Version | Time is now: 15th July 2025 - 04:11 AM |
