lack of power, Need Help |
monkeywrench |
May 8 2005, 05:03 PM
Member Group: Members Posts: 51 Joined: 27-March 04 From: Long Beach Member No.: 1,854 |
I lack Power. The car idles fine. But is running Hot. Have adjusted the valves - Twice. Vacume is steady at 15psi. New Fuel Filter. Just had the injectors cleaned.
Frustated, and Stumped Any recomendations? If it is the valves It is beyond me to pull the engine and what ever may come next. Can anyone help or recomend a good shop in S. Cal. near Long Beach. |
pete-stevers |
May 8 2005, 05:50 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
you can put your car on jackstands (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) .....start looking for a six (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) ....and call it a coversion project..... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
redshift |
May 8 2005, 05:53 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
What is your timing situation? Over advanced?
Idles fine, runs hot... have you checked for caked on/built up crap under the cooling tin? M |
Dr. Roger |
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Running hot.
Lack of power. Classic symptoms of retarded timing. Just advance one degree at a time until you hear detonation at full throttle and then back it off a degree. Make sure you get ZERO pinging or it's a short life span for you engine. Your welcome. |
monkeywrench |
May 8 2005, 06:49 PM
Will Try to play with the timing.
Lo-Fi Version | Time is now: 29th May 2024 - 05:04 AM |
