Trouble in subi land |
Front yard mechanic |
May 3 2017, 05:56 PM
Senior Member Group: Members Posts: 1,172 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I'm looking for subaru 3.0 engine parts / rebuild kits and don't see many options it's making me second guess using this engine anyone have a good source?
theleschyouknow |
May 3 2017, 06:32 PM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
https://forums.nasioc.com/forums/index.php
don't know if it came out of an impreza but maybe try here (IMG:style_emoticons/default/beerchug.gif) cjl |
May 3 2017, 07:55 PM
https://forums.nasioc.com/forums/index.php don't know if it came out of an impreza but maybe try here (IMG:style_emoticons/default/beerchug.gif) cjl Many thanks I have some reading to do |
76-914 |
May 3 2017, 08:28 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Complete JDM's are <$1000. I'm running one now. Bought it w/ 135psi on all 6. When it becomes a problem it's going to the recycler. I pulled one down w appx 175k on it and I could still see the cross hatch markings on the cylinder walls.These are basically 300k engines with minor maintenance. Most will show signs of an oil leak adjacent to the oil filter. There's an O-ring that wears out. Takes about 20 minutes to change and cost $13. If you were to do a timing chain job your out about $500 including tensioners and guides. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 10:44 AM |
