| xicema17x |
May 15 2017, 02:39 PM
Newbie ![]() Group: Members Posts: 5 Joined: 15-May 17 From: San Diego Member No.: 21,102 Region Association: Southern California |
Hi All,
Curious if you might be able to identify the pix below. The car sat for quite some time, and my assumption is the previous owner did not know how to do an oil change. **The car was spitting out white smoke, which I believe is due to an overfilling issue?** Anyhow, I took out some oil, and it helped. Now I am in the position where the car seems to run very rich, and my assumption is the cylinder head temp sensor is missing or not functioning properly. Can anyone help identify if the cut wire below, if it is the temperature sensor wire? Also, can anyone help identify the white plug below please? (IMG:http://www.914world.com/bbs2/uploads_offsite/i28.photobucket.com-21102-1494880783.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i28.photobucket.com-21102-1494880783.2.jpg) |
| 914_teener |
May 15 2017, 03:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
What year and size motor is it?
| Dave_Darling |
May 15 2017, 03:15 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,367 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The first one looks a lot like the CHS sender wire. See where it goes; if it disappears through the engine tin near the #3 spark plug, that's what it is.
The second one looks like a connector for the fuel-cut type rev-limiter, as used on 75-76 914s that had catalytic converters. No harm if it is not plugged in. --DD |
| xicema17x |
May 16 2017, 07:51 PM
| xicema17x |
May 19 2017, 11:44 AM
The first one looks a lot like the CHS sender wire. See where it goes; if it disappears through the engine tin near the #3 spark plug, that's what it is. The second one looks like a connector for the fuel-cut type rev-limiter, as used on 75-76 914s that had catalytic converters. No harm if it is not plugged in. --DD Thanks Dave... Found the culprit! I appreciate it... |
Lo-Fi Version | Time is now: 17th November 2026 - 06:05 AM |
