7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
I'm running polished 4 bolt Fuchs now and I have an itch to go a little more racy. I like the looks of widened steel wheels. Called around and I see a couple places that will cut the center out and put it in a new wider rim but the only hitch is I have to find a steel wheel with 4x130 and enough backspacing.
i want this for a narrow body car so no flares. Are the only options the sundial steel or the stock steel wheel? Both kinda ugly. Wonder why it's impossible to find a 15x7, 4x130, 5" backspaced wheel.... Maybe convert to 4x100 and put fwd wheels on? Whose running widened steelies? Selling a set? |
AZBanks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region ![]() ![]() |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
There are companies that will cut your wheels, weld in a band of metal, and widen them in that way. However, I think the idea of using new barrels makes a whole lot of sense, though they may not look totally accurate.
BigFour1973 |
Member ![]() ![]() Group: Members Posts: 187 Joined: 16-November 14 From: Long Beach Member No.: 18,126 Region Association: Southern California ![]() |
Why are 9" wheels so hard to find in the aftermarket? It seems 95% of them jump from 8 to 10.
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
If you swap to 5 lug, there is a set of 5 or 7 15x7 Centerline wheels with the perfect offset to fit under the stock fenders.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I looked around and I m at loss. I thought wide steel be beetle wheels were available at all the usual sellers but I can up blank.
PotterPorsche |
Member ![]() ![]() Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None ![]() |
Lo-Fi Version | Time is now: 15th June 2024 - 10:34 PM |
