Speedo Failure |
Speedo Failure |
bd1308 |
May 11 2005, 05:50 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
I was driving and the speedo was stuck on 60 the whole way home. Stopped at a light and it went to zero and never moved since. The odometer works perfect but the speedo hardly works at all. I took it apart and found grease all over the cup that is connected to the needle...grease all over everything. Is this normal? Should I grab another speedo, or use a bike speedo?
ChrisReale |
May 11 2005, 06:21 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
did ya check the speedo cable?
nebreitling |
May 11 2005, 06:32 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
use a bike speedo.
bd1308 |
May 11 2005, 06:41 PM
speedo cable was fine.....the odometer was doing awesome...ticking miles by and by ...where is the angle drive? I wanna see this thing. Already have the car on RaMpS
Mueller |
May 11 2005, 06:44 PM
follow the cable to back of the car...........
lapuwali |
First time I've heard of the speedo failing but the odo working. Usually the other way around. Can't be the cable if the odo works.
You can look for a speedo shop in your area to see if you can get it fixed. Or send it to PA or NH Speedo to have them fix it (expensive). Or buy a VDO electronic speedo that reads off a VW speed sensor adapted to your cable (about the same in price). Or buy a used speedo off Ebay (not so expensive). Or use a bike speedo (Sigma Sport BC800, goes up to 188mph, has both trip and regular odos, switchable between mph and km/h, about $25). Bad things about bike speedos: they don't have lights in them, so you can't see it in the dark unless you cobble up something; rigging up the magnet and sensor are sometimes a real pain. You'll need to attach the magnet more or less permanently to something (I used superglue when I did this on my Mini), and you'll need to make up a bracket to hold the sensor reasonably still and within 4mm of the magnet. Any wobbling of the sensor mount will throw off the speed reading. They look like a digital watch is stuck to your dash. Good things about bike speedos: you can calibrate it to within 0.01mi or 0.1mph of being exactly correct if you have the patience; they work even in reverse; no cable to fail. |
bd1308 |
May 11 2005, 07:08 PM
bike speedo was a joke.......I'm going to the VW shop to see if the guy has a VW speedo i can use for the time being, or if he actually has a VDO speedo...these damn things look so simple, and it looks.....WAIT a sec. I think i got it. |
ben1440 |
May 11 2005, 07:22 PM
Member Group: Members Posts: 171 Joined: 1-March 05 From: Santa Rosa Ca Member No.: 3,688 |
not trying to steal the thread or anything, but what is the deal if the speedometor works but not the odometor. Is that the speedo or the cable?
bd1308 |
May 11 2005, 07:26 PM
somebody hold my beer.....
there is a gearset that advances the odometer, and when the factory made these guages, they didnt score the rod when putting on the gear, so when year 30+ rolls around, they strip and dont work, IE the gear spins but the rod doesnt. |
Mueller |
May 11 2005, 07:37 PM
think about it (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) ....no cable, and nothing will work (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Demick |
May 11 2005, 08:01 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
There's a good article on Pelican on how to fix that. Common problem. Demick |
Lo-Fi Version | Time is now: 5th June 2024 - 07:48 AM |
