Fresh Air Control Unit Lamps |
Kansas 914 |
Jun 1 2017, 01:34 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
Well after 45 years my lamps are burned out on the fresh air control unit.
PET says the bulb is a 900.631.129.90 but Google returns no results. I looked at some 911 places and maybe 900.631.132.90 is the replacement. Does anyone know if there is an LED for this lamp? What is the base called (like BA9 for gauge lamps)? I don't want to do this again in 45 years... (IMG:style_emoticons/default/smile.gif) |
db9146 |
Jun 1 2017, 08:16 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I believe that the small lights in the gauges are BA7S-Ws ...have you looked at these?
Kansas 914 |
Jun 2 2017, 08:22 AM
Kansas 914 |
Jun 2 2017, 08:27 AM
I believe that the small lights in the gauges are BA7S-Ws ...have you looked at these? Not yet - but I will now - thanks! I just looked at BA7 lamps and they have a base - the ones I need just have bare wire bent over each side. It is like this bulb #555 used in pinball machines except much smaller. |
LowBridge |
Jun 2 2017, 08:43 AM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
Kansas 914 |
Jun 2 2017, 01:29 PM
Thanks! I found it on the Bird Board for $1 each. I still would like an LED equal but these will work fine - cheers! |
914_teener |
Jun 2 2017, 02:33 PM
914 Guru Group: Members Posts: 5,204 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Thanks! I found it on the Bird Board for $1 each. I still would like an LED equal but these will work fine - cheers! I have the same need. Is it possible to post the source other than AA? |
Kansas 914 |
Jun 2 2017, 02:39 PM
I have the same need. Is it possible to post the source other than AA? http://www.pelicanparts.com/More_Info/9006...-631-132-90-M97 |
914_teener |
Jun 2 2017, 02:58 PM
Great...thanks!
bbrock |
Nov 18 2019, 06:03 PM
Bumping this thread to see if anyone knows of an LED replacement... or just the stinking bulb base/size so I can look for myself. EDIT: I think I answered my own question. Looks like they are 2721 bulbs. If so, dirt common and several led options available. I'll pick a couple up at the FLAPS tomorrow and confirm. |
Mikey914 |
Nov 19 2019, 12:55 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Pretty sure I have the LEDs in stock.
I will check in the morning and let you know. Mark |
Lo-Fi Version | Time is now: 1st June 2024 - 07:23 PM |
