No power in running part of key switch., Need help figuring this out |
wilchek |
Jun 3 2017, 07:57 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
Was driving the car stopped to get gas. When I went to start the car I had no power to switch in the run position. No light on dash etc. When I go to the start position I got it to turn over but not run as soon as I go back to run position. Thinking​ this is the switch but could it be something else like the board, ground, fuse or computer. Any suggestions in what connections to check that commonly fail. Any help is appreciated.
Porschef |
Jun 4 2017, 05:29 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
A catastrophic fail like that is most likely the ignition switch, especially since it would seem you did nothing prior to it running except add gas. I was able to purchase one through Porsche, getting past the cheap Chinese repros that seem to have a high failure rate. The extra $ are well worth it.
Good luck. (IMG:style_emoticons/default/beerchug.gif) |
wilchek |
Jun 4 2017, 09:47 AM
End up being the switch. When I got it apart it was cracked.
Lo-Fi Version | Time is now: 8th June 2024 - 06:30 AM |
