tomh |
Member ![]() ![]() Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None ![]() |
Could someone explain the exact path of the wire from the engine to the oil temp gauge.
A complete stock 74 2.0 with center counsel. Thanks all |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,967 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Its a single green/black stripe wire. For a 74 it runs between the sender and the box connector under the battery tray coming out of the chassis harness. The wire in the chassis harness goes to the oil temp gauge connection in the center console.
The wire is attached to the motor at three points by sheet metal brackets which are crimped onto the wire. 1. The first connector is attached to the sender cover plate. From here the wire routes above the motor mounts. 2. The second connector attaches to the lower mount bolt for the oil filter console. 3. The third connector attaches to the lower oil cooler to fan housing bolt. |
tomh |
Great, I appreciate the detailed info.
LowBridge |
Member ![]() ![]() Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States ![]() |
Its a single green/black stripe wire. For a 74 it runs between the sender and the box connector under the battery tray coming out of the chassis harness. The wire in the chassis harness goes to the oil temp gauge connection in the center console. The wire is attached to the motor at three points by sheet metal brackets which are crimped onto the wire. 1. The first connector is attached to the sender cover plate. From here the wire routes above the motor mounts. 2. The second connector attaches to the lower mount bolt for the oil filter console. 3. The third connector attaches to the lower oil cooler to fan housing bolt. (IMG:style_emoticons/default/blink.gif) .. you need to get out more (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 3rd July 2025 - 01:55 AM |
