Brakes, Poor braking performance |
gkk |
Jun 24 2017, 08:41 AM
Newbie Group: Members Posts: 6 Joined: 30-July 16 From: SW Ontario Canada Member No.: 20,240 Region Association: Canada |
I have a 74 2.0 all stock. Brakes are mushy and I can't get them to lock up. New pads, caliper inspection and bleed has done little. I would appreciate upgrade advice that does not require significant modification. Would a new 17mm cylinder help?
Spoke |
Jun 24 2017, 08:44 AM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Sounds like there's still air in the system. Check the proportioning valve in the engine compartment. I've heard it can trap air even when bleeding.
Were you doing pressure bleed, pump-brakes bleed, or vacuum bleed? |
infraredcalvin |
Jun 24 2017, 09:15 AM
Distracted Member Group: Members Posts: 1,528 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
New rubber lines?
gkk |
Jul 13 2017, 02:12 PM
I have a 74 2.0 all stock. Brakes are mushy and I can't get them to lock up. New pads, caliper inspection and bleed has done little. I would appreciate upgrade advice that does not require significant modification. Would a new 17mm cylinder help? Lines bled by two different mechanics. Will ask how. I have heard that valve can be an issue |
mepstein |
Jul 13 2017, 02:34 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 9th June 2024 - 10:52 PM |
