jcambo7 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,691 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest ![]() |
So after a little over three years I finally got some free time and money to get my 914 running again. Got her started up after changing oil, filter, and cleaning the gas tank. While I was trying to start it again after it quit running while I was tuning the carbs I found the ignition rotor to be fried and melted a bit.
Attached thumbnail(s) ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,209 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Heat melted it. (No s**t, Dave!) The heat is likely caused by resistance and lots of current. Usually there is a decent amount of current and very low resistance here.
First, do you have a "super" coil of some kind? The 914 seems to work best with a coil that has a resistor, either incorporated into the coil (as in stock or Bosch blue coils) or externally. Next, what does the inside of the cap look like? How about the connections on the plug wires, and the plug itself? --DD |
jcambo7 |
Heat melted it. (No s**t, Dave!) The heat is likely caused by resistance and lots of current. Usually there is a decent amount of current and very low resistance here. First, do you have a "super" coil of some kind? The 914 seems to work best with a coil that has a resistor, either incorporated into the coil (as in stock or Bosch blue coils) or externally. Next, what does the inside of the cap look like? How about the connections on the plug wires, and the plug itself? --DD I have an MSD coil. The cap, wires and plugs look fine. No burn marks or fried wires elsewhere. |
michael7810 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region ![]() ![]() |
The rotor in my car lasts about 8-10K miles before it fries. Never looked as bad as yours but the epoxy on top burns and cracks and that causes a severe misfire. I just changed it after 6K miles because the epoxy was getting black although it was still working OK. I have MSD and set my plug gap at .042. I figure the MSD plus larger plug gap are causing the shortened life.
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,456 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
If you're using a high-performance coil, you need to dig the resister out of the epoxy. From there you will need to solder in a piece of stranded copper wire to take its place. I believe John at aircooled.net sell these premade.
michael7810 |
If you're using a high-performance coil, you need to dig the resister out of the epoxy. From there you will need to solder in a piece of stranded copper wire to take its place. I believe John at aircooled.net sell these premade. Thanks. I'll contact John and see what he has. I'm using an MSD Blaster coil |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,896 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Looks like he is running a six,skipped MSD has not proved to be up there for dependable service,other opitions are out there.
Massive resistance @ that rotor,bad leads or fused points....who knows,don't understand why anyone runs points anymore...that's the bottom line. |
'73-914kid |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California ![]() ![]() |
CB Perfomance sells a new rotor with just a brass strap. No funny business with soldering in a heavy wire. Only downside is that you lose the ability to run a Rev limiting ignition rotor.
https://www.cbperformance.com/product-p/2004.htm |
jcambo7 |
Looks like he is running a six,skipped MSD has not proved to be up there for dependable service,other opitions are out there. Massive resistance @ that rotor,bad leads or fused points....who knows,don't understand why anyone runs points anymore...that's the bottom line. It is a six. I had the pertronix magnetic pick up on it when I bought the car but it kept having issues. I went through two or three of them. When I had sixnotfour look at it since he built the engine he swapped it back to points. |
'73-914kid |
Do you run an MSD box, or just the MSD coil with pertronix?
jcambo7 |
yeahmag |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,920 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Have John get you e non rev rotor from worldpack
jcambo7 |
michael7810 |
CB Perfomance sells a new rotor with just a brass strap. No funny business with soldering in a heavy wire. Only downside is that you lose the ability to run a Rev limiting ignition rotor. https://www.cbperformance.com/product-p/2004.htm That's a smokin' deal if it fits your distributor. I don't think it will fit mine and just ordered one from Airooled.net for 3.5X the price to fit my Aircooled.net SVDA. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Looks like he is running a six,skipped MSD has not proved to be up there for dependable service,other opitions are out there. Massive resistance @ that rotor,bad leads or fused points....who knows,don't understand why anyone runs points anymore...that's the bottom line. Sounds like you've been talking to guys using cheap ebay Chinese MSD clones. Sure a MSD can fail, but it doesn't happen often to the real deal. The old 6al is gold to the V8 crowd up here. Nothing wrong with running a MSD with points, with a MSD the points become a simple low voltage on/off switch, they don't burn like on a stock system. I've seen more pertronix failures than points failures. On the side of the road I can fix points with a screwdriver and a folded business card. Failed pertonix and yer done, call AAA. I agree ditch the rev limiting rotor and use the MSD for rev limiting. |
HarveyH |
Member ![]() ![]() Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 ![]() |
yeahmag |
That's exactly how I did it before I switched to a Mallory Dizzy.
jcambo7 |
Could this had fried the distributor also if I kept trying to start the engine a few times or more before I noticed the rotor being fried?
'73-914kid |
I would be very surprised to see any damage to the points. With an MSD box, they are just a trigger mechanism.
For a quick test, grab a vw type 1 rotor (with resistor would work fine for a quick test) and try and start it. Brief running time on the rotor won't damage anything. |
Lo-Fi Version | Time is now: 1st August 2025 - 03:41 PM |
