80cap |
Member ![]() ![]() Group: Members Posts: 322 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None ![]() |
Tire size 205 60 15. checks good with GPS speedometer with the car speedometer.
(IMG:style_emoticons/default/beerchug.gif) |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,958 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
195x65x15 is another size that works well. Both sized typically fit under a stock narrow body with 2.0 Fuchs.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I run 205/60 15's. My speedo reads about 7% fast. I've actually swapped 5 different speedos to check this. They all read the same. If yours reads correct with those size tires, your speedo is off, or has been readjusted.
80cap |
Curt
It checks against the GPS on my phone. If it is correct it will be the first thing on the car that doesn't need tweaking. Brian |
Lo-Fi Version | Time is now: 8th July 2025 - 04:03 PM |
