| Matty900 |
Jul 5 2017, 01:46 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
So much sticky goo on the defroster vents. Is that whats left of the original seals or was there an adhesive used too?
Attached thumbnail(s) |
| malcolm2 |
Jul 5 2017, 06:36 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
IIRC, the 914rubber.com seals come with glue on one side. Just remove the tape-like backing. I slid mine on then trimmed the backing and pulled it off. Did it that way so they would not stick in the wrong place going over the wide horn.
Scrape off what you can, get some GOO-gone and keep scraping. |
| raynekat |
Jul 5 2017, 07:03 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
The sticky goo you see is basically what is left of some of the foam that has decomposed or degraded over the years.
Malcolm2 above has a great idea for sliding the new seals on. |
| Matty900 |
Jul 5 2017, 10:36 PM
IIRC, the 914rubber.com seals come with glue on one side. Just remove the tape-like backing. I slid mine on then trimmed the backing and pulled it off. Did it that way so they would not stick in the wrong place going over the wide horn. Scrape off what you can, get some GOO-gone and keep scraping. Thank you. I got all of the goo off. I like the Idea of pulling the backing off after it is on. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 29th April 2026 - 03:46 PM |
