Headlight motor relay locations? |
steuspeed |
Jul 22 2017, 04:50 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
One of my pop up head lights quit working. Where are the relays located? (IMG:style_emoticons/default/smash.gif)
ejm |
Jul 22 2017, 04:53 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Under the plastic cover beside the motor. Swapping them side to side is a good test.
steuspeed |
Jul 22 2017, 05:05 PM
Under the plastic cover beside the motor. Swapping them side to side is a good test. Exactly! Thanks (IMG:style_emoticons/default/beerchug.gif) |
ConeDodger |
Jul 22 2017, 05:19 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Got a pair sitting on a shelf. Free to good home if you need them.
steuspeed |
Jul 23 2017, 07:58 PM
The suspect relay just needed a wiggle. It's working fine now. The car sat all winter, so that's what I was hoping. (IMG:style_emoticons/default/beerchug.gif)
cary |
Jul 23 2017, 09:32 PM
The suspect relay just needed a wiggle. It's working fine now. The car sat all winter, so that's what I was hoping. (IMG:style_emoticons/default/beerchug.gif) Stewart, Run a razor down thru the legs on the relay to create a better connection. Spreads them out. |
porschetub |
Jul 24 2017, 01:25 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
The suspect relay just needed a wiggle. It's working fine now. The car sat all winter, so that's what I was hoping. (IMG:style_emoticons/default/beerchug.gif) Stewart, Run a razor down thru the legs on the relay to create a better connection. Spreads them out. That worked really well for me on 2 of my relays the had bad connection. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:14 PM |
