Grilling Charcoal in a can, Repacking a charcoal canister |
forrestkhaag |
Aug 8 2017, 10:38 AM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Does anyone have a source for activated charcoal and some indication of its effectiveness verss a 40 something original can for venting the gas tank? Thanks
(IMG:style_emoticons/default/beerchug.gif) |
mbseto |
Aug 8 2017, 11:00 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Activated charcoal is used in filters for aquariums, you can get it at a pet store. Generally it is packed into a filter bag, but it is not expensive by any means. That said, I have no idea what form it takes in the 914 can, pellets or whatever.
bbrock |
Aug 8 2017, 11:13 AM
Did some searching on this a few months ago and was led to
this activated carbon on Amazon Here are two good threads on the subject: http://www.914world.com/bbs2/index.php?sho...108524&st=0 https://www.thesamba.com/vw/forum/viewtopic.php?t=389074 I didn't care for the look of the pipe bung suggested in the Samba article, so opted for these plastic plugs on ebay for a more finished look. The project is still on my to-do list but I have all the materials to refresh the canister when I get to it. |
saigon71 |
Aug 8 2017, 03:17 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I bought some from ebay to repack my charcoal canister. Worked well!
Amphicar770 |
Aug 8 2017, 03:38 PM
Senior Member Group: Members Posts: 1,197 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Here is what I used. Worked great.
Acurel LLC Economy Activated Filter Carbon Pellets, 3-Pound https://www.amazon.com/dp/B000YIWT0M/ref=cm...a_H5IIzbBV0EKRP |
howlndog |
Aug 9 2017, 10:28 AM
Newbie Group: Members Posts: 19 Joined: 8-February 11 From: Winnipeg, Manitoba Member No.: 12,680 Region Association: Canada |
In researching which activated charcoal (carbon) to use for recharging the canister in my 911, I discovered that there are countless products which are termed "activated carbon". It turns out that each has been designed and manufactured for a very specific and intended purpose - whether it be water filtration, fuel emissions, or filtering any number of harmful vapours. Accordingly, each product has its own specific base material (coal, wood, coconut), porosity, shape, and manufacturing processes, etc. The science behind this is overwhelming... and my head was left spinning!
In the end, and to be sure I got the right stuff, I decided to salvage material from a new canister designed for gasoline vapour emissions... this is similar to what I got: http://www.autozone.com/engine-management/...archText=vc4345 Hope that helps. |
mzalanka |
Aug 9 2017, 12:11 PM
Member Group: Members Posts: 116 Joined: 11-July 11 From: Portland, OR Member No.: 13,300 Region Association: None |
Bought this item: http://www.ebay.com/itm/New-Dansk-Vapor-Ca...cuc&vxp=mtr 20 bucks. Sawed it open, used a screwdriver to pop open the old charcoal canister, poured the good stuff on in. Was even able to use the spring in the Dansk canister to replace the rusted out original in the teener's can. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:29 AM |
