Adjusting Idle Help, Low idle after warming up - '73 |
vesnyder |
May 20 2005, 12:34 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
Thought it would be obvious, but cannot find an easy way to adjust the idle on a '73 with D-Jet? It runs fine until it warms up, then it idels at about 100 RPM - when it stays running?
Thanks |
SLITS |
May 20 2005, 01:08 PM
1st....Buy a Haynes Manual (cheap).
2nd...there is a idle screw on the throttle body (location depends on whether you have a 1.7 or 2.0). This is used to adjust the idle on a fully warmed up engine (the AAR has closed and is no longer supplying additional air) 3rd....on your ECU you will have an idle mixture knob...intially set it midrange. 4th.....Check your timing and the rest of the ignition settings. (see #1 above) 5th....Check your fuel pressure (see #1 above) 6th....Check the valve adjustment (#1) |
Bleyseng |
May 20 2005, 02:15 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
#1 problem is that guys adjust the idle speed with the AAR valve partway open, the engine only warm. Engine heats up to operating temp and the AAR valve closes and Bingo! idle speed is at 300 rpms. Huh (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) You can just plug the AAR valve hose and then set it...but thats cheating. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
redshift |
May 20 2005, 03:04 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
But it will tell you if you have a GOOD AAR or not! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
Lo-Fi Version | Time is now: 16th June 2024 - 06:54 PM |
