Clutch pedal return spring, Should pedal stay up? |
DaveO90s4 |
Sep 20 2017, 02:57 PM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
Hi all,
With my clutch cable disconnected from the transmission my clutch pedal falls to the floor. That in turn means the only way (at present) to keep it up is to attach the cable at the transmission and adjust the turn nut. But this would mean, I think, that the clutch throw out bearing would be permanently engaged. So I think I have a problem with the return spring under the pedal assembly. I can see it is not broken, maybe just needs more tension (another turn) to do its job. Not much room to get in and do things down near the pedals and front of tunnel. What do you reckon? Thanks Dave Oz |
ChrisFoley |
Sep 20 2017, 03:08 PM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The spring pulls the clutch pedal downward.
The throwout bearing is always lightly engaged. |
SirAndy |
Sep 20 2017, 03:14 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
With my clutch cable disconnected from the transmission my clutch pedal falls to the floor. Working as intended ... (IMG:style_emoticons/default/shades.gif) |
DaveO90s4 |
Sep 21 2017, 04:27 AM
Thanks Gents,
One less thing for me to have to fix then. Great. In my 356 having the thrust bearing permanently engaged is a big no no. Oh well, this arrangement clearly works. Best regards Dave O Oz |
barefoot |
Sep 21 2017, 05:03 AM
Senior Member Group: Members Posts: 1,276 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Seems backward to me, every other car I've owned sprinted pedal to up position
What were they thinking ??? |
IronHillRestorations |
Sep 21 2017, 05:56 AM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
They were thinking "keep light pressure on the throw out bearing" and "keep the slack out of the cable"
Lo-Fi Version | Time is now: 23rd May 2024 - 02:02 AM |
