Air fuel ratio |
Air fuel ratio |
Dave97 |
Sep 24 2017, 04:45 PM
Newbie Group: Members Posts: 44 Joined: 25-July 17 From: Calif Member No.: 21,285 Region Association: None |
What is the recommended a/f ratio? I have a 2270 with 44 idf Webers. I have a AEM monitoring gauge Thanks. Dave
porschetub |
Sep 24 2017, 05:14 PM
Advanced Member Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Will take a stab @ 12 to 1 ,I want to get one of them myself, (IMG:style_emoticons/default/beerchug.gif) .
Mark Henry |
Sep 24 2017, 06:30 PM
Depends how stable through the full range, 12.5 to 13.5:1, but on load and cruise you don't want more than 13.5:1 at any time.
McMark |
Sep 25 2017, 06:03 AM
Mark Henry |
Sep 25 2017, 08:45 AM
Just as an FYI I'll add that with LN Nickies you can push the AFR as high as 14:1.
Iron no more than the 13.5:1 My T4 powered VW bug has Nickies and I run 14:1, you can do this because of the aluminum cylinders superior heat transfer rate. |
michael7810 |
Sep 25 2017, 12:37 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Just as an FYI I'll add that with LN Nickies you can push the AFR as high as 14:1. Iron no more than the 13.5:1 My T4 powered VW bug has Nickies and I run 14:1, you can do this because of the aluminum cylinders superior heat transfer rate. Is max 13.5:1 at WOT? My car runs 12.5:1 at WOT but cruising down the freeway at 70 mph and light load at the very top of the idle jets the AFR is ~16:1. The second I put my foot into it to climb a grade it drops back to < 13.5:1. I only see CHTs >335F on a long steep grade, then CHT can climb to 375F. Thanks for clarifying. |
Lo-Fi Version | Time is now: 17th June 2024 - 01:34 AM |
