Oil Pressure light, won't go off - ever! |
Markl |
Oct 13 2017, 02:16 PM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
Hey all,
Went for a drive this AM - the oil pressure warning light came on. Coasted home,and started trouble shooting. If I ground the green/red wire to the OP switch, lamp should go off, right? Simple enough, but the light stays on. Checked switch, checked continuity of green/red wire from switch to light. Both are fine, but light never goes out. Ideas? And thanks in advance. |
timothy_nd28 |
Oct 13 2017, 02:45 PM
If you ground the green/red wire at the switch, the lamp should illuminate. If you simply pull the wire off the switch, it should not be lit. If it is still illuminated, then you probably have a short in the harness somewhere.
Markl |
Oct 13 2017, 05:15 PM
Thanks, Timothy, that's what I thought. I ran a separate wire and everything works as it should. Probably in my nasty FI harness.
Lo-Fi Version | Time is now: 11th June 2024 - 10:38 AM |
