Another long awaited part from 914Rubber.com, 19mm master cylinders 911.355.012.02 |
Mikey914 |
Oct 29 2017, 01:06 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes over 2 years to make the much needed alternative at a reasonable price.
Attached thumbnail(s) |
dr914@autoatlanta.com |
Nov 15 2017, 01:04 PM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Thank you for making them Mark, but as you probably know, URO has made these now for quite a few years and they can easily be retailed for 75 each, and you could have made money on them, so why did you spend the money on tooling? We have not had a problem with them (very very small failure rate) and they include the new brake switch as well
rhodyguy |
Nov 15 2017, 02:15 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Why? (IMG:style_emoticons/default/WTF.gif)
Mikey914 |
Nov 15 2017, 07:04 PM
Well, George the URO I had failed in about 10 pumps. It was an internal failure. That and I made an easier to install version.
I did a write up on it that and a basic FU to URO. I'm dropping down on them in other markets too. Pretty easy when they have the reputation they do. |
kaiserms |
Nov 28 2017, 01:31 PM
MSKaiser Group: Members Posts: 26 Joined: 8-September 16 From: waterford, michigan Member No.: 20,378 Region Association: Upper MidWest |
What is the price on the 19mm master cylinder?
MarkKaiser kaiserm34@yahoo.com 248 766-2159 |
Lo-Fi Version | Time is now: 1st June 2024 - 03:08 AM |
