74ravenna |
Member ![]() ![]() Group: Members Posts: 472 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States ![]() ![]() |
Before i put any time into repainting my wheels how can i tell if they're true?
They're a set of steelies. There is one obvious ding in one of them, but the others look ok. I bought four Pedrinis once but decided against using them so i sold them. The buyer complained that two of them were no good so i reimbursed him for those two. I know it must be a simple test. Is it as simple as spinning them on a dowel or spindle of some sort? tia |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,963 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Yes, anything that will let you spin them easily. You should be able to see if the lips are flat spotted or the wheel is out of true.
74ravenna |
Excellent.
Thanks mepstein.. |
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,413 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
Best way to check wheels to see if there true, run them on a tire ballancer, with out the tires.
jesse7flying |
Member ![]() ![]() Group: Members Posts: 137 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None ![]() ![]() |
I had a couple of old Fuchs wheels with some curb rash on them and took them in to my local Firestone shop. They spun them up on the wheel ballancer and they spun up true. A bit ugly, but true. Didn't even charge me for it.
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,831 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
If you have a regular tire shop you use, they'll probably spin them for very little.
Alternately you could bolt them to the front spindle, and use a dial indicator, or mock up a reference pointer. If they are steel wheels and you don't see any deformities or repair witness marks, they are more than likely fine. Those things are pretty durable |
Lo-Fi Version | Time is now: 11th July 2025 - 06:52 AM |
