early pinch style struts with late ball joints, would you do it? |
jmitro |
Nov 30 2017, 07:06 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
Ok so in a late night shopping frenzy I ordered late ball joints and lock pins (my car is a 74) but after buying 71 911T front struts (pinch style) I realized they use the early ball joint. (IMG:style_emoticons/default/headbang.gif)
I know....dumb move. The early strut still fits over the late ball joint and I can thread an M10 bolt through the pinch bolt hole. Is it considered safe/acceptable to use this combination? Obviously the wedge style lock pin doesn't work. (or does it???) |
mepstein |
Nov 30 2017, 07:27 PM
914-6 GT in waiting Group: Members Posts: 19,283 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
No. You need the correct ball joints.
914Sixer |
Nov 30 2017, 07:40 PM
914 Guru Group: Members Posts: 8,888 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Mark is right. You should not have any trouble selling the late ball joints.
As a side note, I wondered why not drill out the thread portion and put a wedge pin in place of the M10x30 bolt. I think it might be something to play with BUT NOT with a good strut. |
IronHillRestorations |
Nov 30 2017, 08:02 PM
I. I. R. C. Group: Members Posts: 6,720 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The wedge pin is tapered, so I don't think you could just drill it out. I think it's smaller diameter than the pinch bolts
jmitro |
Dec 1 2017, 05:12 PM
Ok thanks.
I also ordered the correct ball joint installation socket. |
Lo-Fi Version | Time is now: 23rd May 2024 - 02:36 PM |
