Lost 2nd Gear! |
Lost 2nd Gear! |
pthughes |
Dec 2 2017, 04:12 PM
Newbie Group: Members Posts: 7 Joined: 11-July 17 From: Oregon Member No.: 21,245 Region Association: None |
Hi All,
looking for guidance...hopeful to get some get some happy news or advice 1976 914, 2.0L Completely out of the blue, 2nd gear is lost. I can put clutch in, shift to 2nd, but when let clutch out, motor does not power the tranny. Nada The was no noise, grind, leaks, etc. Any clues on what this could mean? My guesses are currently the shift fork to 2nd is somehow bad, or maybe the shifter adjustment up in the cab. (it has a short shifter from PO) Shifter, since my purchase, is tight thru all gears. But I got used to it. I know not a thing about transmissions. Pretty sure I do not want to start tearing that down. Any clues as to possibilities for this cause and best way for me to tackle it? Many thanks. |
SirAndy |
Dec 2 2017, 05:06 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Check the main shift coupler first, it's behind the firewall where the shift rod exits into the engine bay.
Check the plastic bushings for play and also check the cone setscrew which can back out. There should be no play in the coupler. If that checks out, check the coupler at the transmission end. (IMG:style_emoticons/default/idea.gif) PS: (IMG:style_emoticons/default/welcome.png) |
pthughes |
Dec 2 2017, 05:55 PM
Check the main shift coupler first, it's behind the firewall where the shift rod exits into the engine bay. Check the plastic bushings for play and also check the cone setscrew which can back out. There should be no play in the coupler. If that checks out, check the coupler at the transmission end. (IMG:style_emoticons/default/idea.gif) PS: (IMG:style_emoticons/default/welcome.png) Will do, have had a chance to look at the coupler at the transmission, attaching pics. I am curious if the plastic bushing is supposed to travel outside of the metal cavity as noted in the pics. I will head under the car north to check the firewall connection also. thanks! (update...cant figure out attaching pics!) Suffice to say, the hard plastic bushing which hold the ball head of the shift rod appears to slide out about 1/8" from the metal housing as I work it thru gears. It appears this is normal, although I cant say for sure. Attached image(s) |
worn |
Dec 2 2017, 07:51 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
At first glance I would say no, it shouldn’t look like that. However it helps to be as precise as possible about the photos. Not sure what I am looking at. Maybe you will be lucky and dr evil will chime in.
mgphoto |
Dec 2 2017, 07:57 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Try moving the lever by hand to engage the gears, if it goes into second definitely the shift linkage.
PlaysWithCars |
Dec 2 2017, 08:13 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Do any of the other gears work? If reverse, 2nd and 4th are all MIA then that's a clue that something is up with your shift linkage and/or adjustment. If its just 2nd, then that sounds like it's something inside the transmission unfortunately.
More information will help to isolate the issue and send you in the right direction for troubleshooting. P.S. I think part of your problem may be that your car is too clean. That part of the linkage, on the side of the transmission, is notorious for collecting all sorts of dust and gunk. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:31 PM |
