Heat Control Flapper Valves, Are the valves on each side the same? |
db9146 |
Dec 3 2017, 07:05 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Got a question on the heater control flapper valves on a -6. On mine, the driver side flapper has a solid cap over one side of the flapper valve while the passenger side flapper valve has a hole about 1.5" in diameter in the cap.
Anyone know the a reason for the one having a hole? |
mepstein |
Dec 3 2017, 07:06 PM
914-6 GT in waiting Group: Members Posts: 19,309 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The one with the hole is original. I’m pretty sure the solid one is a replacement.
Socalandy |
Dec 3 2017, 10:32 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
for 914 and 914-6 there is a left and right. both -6 boxes have the hole as a air bypass
Attached image(s) |
Garland |
Dec 4 2017, 12:42 AM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
rgalla9146 |
Dec 4 2017, 08:57 AM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Trivia.
It's not just the hole on the 6 valves, the corresponding 4 cyl. part is larger in diameter. 4cyl. are black, 6cyl. are grey Attached thumbnail(s) |
mepstein |
Dec 4 2017, 09:30 AM
Rory - if I drilled a 1 1/2” hole in the top of my (four) valves, would it duplicate the sixes in function? Or is their an internal difference.
rgalla9146 |
Dec 4 2017, 11:17 AM
Rory - if I drilled a 1 1/2” hole in the top of my (four) valves, would it duplicate the sixes in function? Or is their an internal difference. Hey Mark The differences I noted are visible from the outside. I believe they function exactly the same. A 4cyl. part with a hole in the cover should be fine. The function of different diameter caps ? Dump capacity ? |
mepstein |
Dec 4 2017, 11:30 AM
Rory - if I drilled a 1 1/2” hole in the top of my (four) valves, would it duplicate the sixes in function? Or is their an internal difference. Hey Mark The differences I noted are visible from the outside. I believe they function exactly the same. A 4cyl. part with a hole in the cover should be fine. The function of different diameter caps ? Dump capacity ? I'll buy that. The 6 fans move a lot of air. Thanks! |
db9146 |
Dec 4 2017, 01:43 PM
So if the hole is only there to dump air, then wouldn't you potentially want them w/o holes to pump more air over the heads on a -6 for cooling?
mepstein |
Dec 4 2017, 01:50 PM
mlindner |
Dec 4 2017, 01:58 PM
Senior Member Group: Members Posts: 1,526 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Sorry to go off track but this question just came up today at Accumoto.
(Are the heater control boxes the same....or can be the same on the four and the six). If we bought new ones for a four they would work on a six?. Best, Mark |
GeorgeRud |
Dec 4 2017, 03:28 PM
Either will fit and work, but the hole in the ones for the sixes must have been there to bleed off more air when the heat is turned off.
Socalandy |
Dec 4 2017, 03:29 PM
Yes but and will have a slightly different angle going to the longs
mepstein |
Dec 12 2017, 12:44 PM
Homemade 6 flapper box.
Found a couple rusty ones. Blasted, cut hole, powder coated. Attached thumbnail(s) |
raynekat |
Dec 12 2017, 06:13 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
mepstein |
Dec 12 2017, 06:23 PM
I think it was 1- 1 1/4”. It was a wurth hole saw that I chucked into the drill press. Drilled the hole, blasted the piece and then powder coated. I had 5 that were pretty rusty but still usable. I hope to make a pair or 2.
I think bdstone charges ~$50 for refurbished flapper boxes. By the time you throw out the broken ones, fix the ones that can be fixed, blast and powder coat, $50+ is a good deal. |
DRPHIL914 |
Dec 14 2017, 08:54 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I sent mine to bruce to be done, he has many of them in his stash, turns out my seals were in good condition , just a bit of cleaning and repainted- but if you are missing anything talk to Bruce he probably has it.
sixaddict |
Feb 8 2022, 10:09 AM
Senior Member Group: Members Posts: 805 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Great information ……
Thanks!! (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 05:58 PM |
