1.7 Been sittin' a while, What do I put in the cylinders? |
alphacrimedog |
Jul 8 2003, 12:18 AM
Newbie Group: Members Posts: 24 Joined: 27-June 03 From: Columbus, GA Member No.: 868 |
(IMG:style_emoticons/default/smilie_flagge6.gif) I am about to get things ready to try and start my car since I got it from the original owner. Its been sitting outside for years, but overall the car is in pretty good shape. It was sitting under the carport on a concrete driveway. I need to replace the gas lines coming from the bottom of the tank to the fuel lines. I'll have the tank boiled out while its out of the car.
I figured since its been sitting a while that I need to remove the plugs and put some kind of lube or something in the cylinders before trying to turn her over ( probably by hand). I was thinking of Marvel Mystery Oil, My Brother-in-law says he likes to use Transmission fluid because of all the detergents in it. What do you guys think is the proper thing to do? |
Drums66 |
Jul 8 2003, 10:40 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Actually..........both idea's are good, I use tranny fluid in situations like that and Marvel mystery oil I use for engine break-in (IMG:style_emoticons/default/cool_shades.gif)
alphacrimedog |
Jul 12 2003, 12:36 AM
How much would you put in each cylinder. Someone suggested that I fill each cylinder but that doesnt seem right. I could see hoe a complete coating in each cylinder may be beneficial, but getting it out would be a real bear. I was figuring on a couple of Tablespoons woorth? Hows thjat sound? (IMG:style_emoticons/default/smilie_flagge24.gif)
Porsche Rescue |
Jul 12 2003, 08:59 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Use a couple of tablespoons of Marvel Mystery oil. Turn it over a few times by hand then use starter to spin the motor with plugs out. That will spread it around and blow it out the plug hole. Maybe a little smoke on start up, but won't last long.
maf914 |
Jul 12 2003, 09:18 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Don't fill the cylinders! Who knows what kind of damage can occur when that piston tries to move through a compression stroke while the cylinder has a huge slug of oil in it. Also if any of the exhaust valves are open it will just run out into the exhaust.
Just add enough to wet the rings. I don't know how well it really does wet the rings, since the cylinders are horizontal and the oil will settle to the bottom. But I did add oil to my cylinders before a lengthy storage and it worked out fine afterwards. Mike |
Lo-Fi Version | Time is now: 28th May 2024 - 02:16 PM |
