Wow! Does a Tune Up Really Make a Difference! |
Tom73 |
May 30 2005, 01:50 PM
Member Group: Members Posts: 180 Joined: 20-September 04 From: Central Texas Member No.: 2,792 |
At last, I completed the tune-up on my '71. Had a bad vac advance and had to order that part. Got it at last and was able to complete everything. Boy, does that ever make a difference. Instant throtle response and it will get on down the road. When I got the car it would bearly get out of its own way. I know it is only a 1.7 but, considering that, it will move it right on out. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Still need to do a bit more fine tuning with the dwell and timing and it should run even better. (Cann't believe the hoops you have to jump through to adj the dwell (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) )
tom... (IMG:http://temp.corvetteforum.net/c5/73vette//914/j2.jpg) |
ChrisReale |
May 30 2005, 01:55 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
get a pertronix or crane unit and forget about the dwell (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
redshift |
Yes, 2.0s aren't that much of a step up.. the others can haul some bootay when you mash the gas. M |
meares |
May 30 2005, 02:06 PM
Member Group: Members Posts: 403 Joined: 23-March 05 From: Atlanta Member No.: 3,800 |
did you get the vacuum adv. from Pel.Parts?
morph |
quality parts builder Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) ditch the points |
Tom73 |
May 30 2005, 02:21 PM
Auto Atlanta. Don't believe that PP had them. AA was cheaper than the local parts house who would still have had to order them. tom... |
type47 |
May 30 2005, 02:37 PM
i gotta hand it to ya... talkin' about 914 performance from a guy who has a 454 'vette (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Tom73 |
May 30 2005, 03:03 PM
That is my baby, three owner and only 50k miles.... (IMG:http://www.corvetteforum.net/c3/vette73/bubba1.jpg) tom... |
Bleyseng |
May 30 2005, 03:39 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I am sure the Vette is his daily driver getting 3 mpg! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
ArtechnikA |
May 30 2005, 04:12 PM
1) rotate distributor body until rubbing block is on high spot of cam. 2) adjust points gap to 0,016" 3) reset timing to book value. done. a points-replacement module (i have one) means you don't have to do even that, but i'm really hard-pressed to find much in the way of oppressive hoops in that procedure... |
type47 |
May 30 2005, 06:25 PM
heh - heh - heh. just checked my mpg last fill up. 29.5 mpg
Tom73 |
May 30 2005, 08:57 PM
Just that I have gotten use to the chevy distributor where you just use an allen wrench to adjust the dwell while the car is running. A much better enginered solution (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Would you believe 13 mpg (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Also have an '04 Vette convertible and it get 29 mpg on the highway. Figure it is my highway econo car. And that is cruising at 80-85. tom... |
Lo-Fi Version | Time is now: 11th June 2024 - 12:59 PM |
