GoWesty Vanagon Billet TB |
pete000 |
Jan 9 2018, 07:08 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Think this little jewel would work on a L-Jet 914?
For a 2.1 Vanagon water boxer. Attached thumbnail(s) |
JamesM |
Jan 9 2018, 07:30 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Looks like you might have issues with the TPS but cant tell for sure. Also if the throttle shaft is different you will have issues swapping the actuation arm with the one on your existing 1.8 throttle body (needed to get the throttle pull in the correct orientation)
I have been running a modified 2.1 vanagon throttle body on a modified 1.8 plenum for years so physically it should be able to fit, may require some additional tweaking to get it working with l-jet though (im running megasquirt on mine) |
Tom_T |
Jan 9 2018, 07:52 PM
Just call the GW owner Lucas Valdez or Mike to ask them if it would work.
Lucas is a former 914 owner too. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
jim_hoyland |
Jan 10 2018, 07:39 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I use a Vanagon 2.1 TB; didn't buy it from Go Westy though. Bought a used one on eBay and sent it to Phil in New Mexico for rebuilding.
There is a thread that addresses the TPS issue |
Lo-Fi Version | Time is now: 9th June 2024 - 02:30 PM |
