Building a 914/6 for spec.... |
Joe Bob |
May 30 2005, 05:54 PM
Picked up a 2.4 with MFI and I'm bidding on a 75 914 on ebay...gonna use all my spare parts and build another street car. Anyone interested? Can be built to suit YOU....
Will come with 911 suspension, Bilsteins in the rear and 911 wheels... |
Allan |
May 30 2005, 05:55 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Make it ride like a Bentley and handle like a Indy car and call me...
Aaron Cox |
May 30 2005, 06:00 PM
mikey no!!!!!
sell me the mfi motor (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Joe Bob |
May 30 2005, 06:06 PM
Everything is for sale..... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Just send money... |
Verruckt |
May 30 2005, 06:07 PM
Senior Member Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
Are you bidding on the "cheese-mobile"??? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
(IMG:http://i1.ebayimg.com/03/i/04/2b/ed/30_12_sb.JPG) |
Joe Bob |
May 30 2005, 06:35 PM
GOD NO.... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
jd74914 |
May 30 2005, 06:49 PM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I might go see that for laughs. I only live 5 miles away (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
michel richard |
May 30 2005, 07:03 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
Mike,
You absolutely, positively have to say which 2.4, otherwise, you're diluting the message ! 2.4T = Hmmm this is interesting, torquey and revs! 2.4E = wowsa these things are rare, exciting, rev at the blink of an eye, and streetable ! 2.4 S = Ohmmeegod, a hot rod for the street, needs all kinds of coolers, super high performance everything, barely streetable, will make one's blood turn over twice when it's busting through 7,000 rpm, on its way to redline ! Michel 914/6 2.2E MFI p.s. putting MFI in a 914 is not for the faint of heart. |
Joe Bob |
May 30 2005, 07:06 PM
I will when I get it....the engine was part of a deal. It's complete but the yahoo was too stoopid to give me a engine number and the deal was too gud to pass on....
davesprinkle |
May 30 2005, 09:30 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Hmmm... I've got a 2.4S down in the garage. But it's not in good shape -- here's the deal:
The PO missed a 3-4 upshift at high revs, accidentally putting the thing in 2nd. By the time he realized the mistake, all 6 exhaust valves were bent. I was given the engine in a dissassembled state. It's all intact, except for 1 cylinder, which is cracked from apparently being dropped. Also, it's missing the MFI stuff. So. What to do? Please tell me your suggestions. 1. Obviously, I'll need to replace the cracked cylinder & all 6 bent valves (sodium filled, ~$120/each, ouch). 2. Should I run the S-cam or go with a milder grind? 3. Stock pistons or high-comp JEs? (Sorry, for those of you who will suggest a set of Euro-spec Mahles, I'm not that wealthy.) 4. Get an MFI setup, run carbs, or modify MFI throttle bodies to run proper electronic fuel injectors? Thanks. -dave |
sixnotfour |
May 30 2005, 09:42 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
If its an S numbered motor sell it to a early 911 guys $$$ "S" MFI $$$
"Z" Do you know the Shroud Colors; 2.4 yellow T, green E or red S ? If no one's messed with it. |
Red-Beard |
May 30 2005, 11:01 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Remember, to run carbs on a MFI motor, you have to weld the MFI port. |
Red-Beard |
On each head
davesprinkle |
May 30 2005, 11:39 PM
Weld up the MFI ports? What about machining a plug?
michel richard |
May 31 2005, 06:18 AM
A plug in the injector ports will work. Keep the S cams they don't hurt streetability on a 2.4 as much as on the smaller displacement engines. IMHO, going to an aftermarket fuel injection is the best option, unless you have can get absolutely everything for the MFI.
Michel |
Joe Bob |
May 31 2005, 07:04 AM
Yellow... |
Lo-Fi Version | Time is now: 11th June 2024 - 12:10 AM |
