Best initial cleaning approach for transmission |
Tdskip |
Jan 18 2018, 07:35 AM
Good morning. The 901 on my project has already been removed from the car. I need to open it up to replace the 2nd gear synchro and it obviously needs to be clear clean clean before I do that.
Is it safe to pressure wash the exterior case so long as I don’t spray where the input shaft is? And been there / cleaned that tips to share? Thanks! |
Front yard mechanic |
Jan 18 2018, 08:02 AM
Senior Member Group: Members Posts: 1,169 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Oven cleaner
sdoolin |
Jan 18 2018, 08:04 AM
Member Group: Members Posts: 359 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
If you are careful around the seals, and tape the breather well, pressure washer will work. I did this a little over a year ago (pressure washer), with no ill effect. I was VERY careful.
914Sixer |
Jan 18 2018, 08:21 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Start out with a small putty knife and clean all that you can that way. It will make the overall cleaning go better
rhodyguy |
Jan 18 2018, 08:28 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/agree.gif) + brake cleaner and a piece of 6mil plastic to work over. Multiple cans. Stinks to high heaven and puts you on the moon.
iankarr |
Jan 18 2018, 09:06 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
First drain all the gear oil. I got a wood movers dolly and screwed some 2 x 4s across it narrower than the bellhousing (using long wood screws through the bolt holes to secure) so the transmission could stand vertically and be easily rotated to get at all the nooks and crannies.
Remove the speedo drive and block the hole. Tape up the vent well and put a tarp under the dolly/transmission as you work. it's a greasy mess. Like 914sixer said, use a putty knife to get all the thick junk. Then I used 4 cans of brake cleaner to loosen it all up. More expensive than oven cleaner, but it seems to work quicker. Then I removed the stub axles to get at the tight spots and used a steam cleaner to do the final cleaning (HF has em for under a hundred bucks and it's my new favorite tool). Finally I painted with Alumi-blast and it turned out great. There's some disagreement as to how much paint (especially silver) contains heat, but I figure it isn't significant and protecting the box from the elements is probably better net-net. If breaking the whole tranny down, I might consider having it dipped to save myself the greasy mess and my wife complaining about stains on the driveway;) |
Bartlett 914 |
Jan 18 2018, 09:08 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I use mineral spirits or naphtha and a small tray. I use a small bristle brush with the bristles cut short. Putty knife and small scrapers to get into cracks. I don't use brake cleaner in spray cans as much because I hate the spray coming back in my face. It also drys a little too fast. It works good as a last cleaner
Tdskip |
Jan 18 2018, 09:20 AM
Thanks for the discussion.
Tomgayer |
Jan 18 2018, 09:26 AM
Newbie Group: Members Posts: 7 Joined: 16-January 18 From: Bossier City , LA Member No.: 21,804 Region Association: None |
First drain all the gear oil. I got a wood movers dolly and screwed some 2 x 4s across it narrower than the bellhousing (using long wood screws through the bolt holes to secure) so the transmission could stand vertically and be easily rotated to get at all the nooks and crannies. Remove the speedo drive and block the hole. Tape up the vent well and put a tarp under the dolly/transmission as you work. it's a greasy mess. Like 914sixer said, use a putty knife to get all the thick junk. Then I used 4 cans of brake fluid to loosen it all up. More expensive than oven cleaner, but it seems to work quicker. Then I removed the stub axles to get at the tight spots and used a steam cleaner to do the final cleaning (HF has em for under a hundred bucks and it's my new favorite tool). Finally I painted with Alumi-blast and it turned out great. There's some disagreement as to how much paint (especially silver) contains heat, but I figure it isn't significant and protecting the box from the elements is probably better net-net. If breaking the whole tranny down, I might consider having it dipped to save myself the greasy mess and my wife complaining about stains on the driveway;) Did you use brake cleaner or brake fluid? i have tons of brake fluid but never thought of using it as a cleaner. Thanks |
iankarr |
Jan 18 2018, 09:45 AM
good catch. I used cleaner. F'in auto correct! Will edit.
mepstein |
Jan 18 2018, 09:54 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Steam pressure washer. 5 minutes and done.
IronHillRestorations |
Jan 18 2018, 09:57 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Steam cleaner. 210* hot water melts a lot of gunk off. Alternately you can use a pressure washer or take it to a DIY spray car wash. As others have said, tape up the seals and breather, I use aluminum duct tape.
After that foaming engine cleaner with an assortment of scrapers, then brake cleaner. Then re-tape and media blast with walnut shells. For a coating I use Dupli-Color spray hi-temp clear |
Dr Evil |
Jan 18 2018, 10:01 AM
Pressure washing is a mixed bag. I have seen corrosion from that technique. If you are pulling the stack anyway, just take the case and have it cleaned at a machine shop in a hot tank. If you are pulling the shafts from the intermediate plate, take that and the tail cone, too. Oven cleaner works best with pressure washer. Pre soak. I have someone else do it, I hate cleaning these things. I have found that acetone works wonders for cleaning up the old varnishy, baked on gunk inside and out.
Justinp71 |
Jan 18 2018, 10:23 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
If you are careful around the seals, and tape the breather well, pressure washer will work. I did this a little over a year ago (pressure washer), with no ill effect. I was VERY careful. (IMG:style_emoticons/default/agree.gif) This is what I did... |
Bartlett 914 |
Jan 18 2018, 10:26 AM
First drain all the gear oil. I got a wood movers dolly and screwed some 2 x 4s across it narrower than the bellhousing (using long wood screws through the bolt holes to secure) so the transmission could stand vertically and be easily rotated to get at all the nooks and crannies. Remove the speedo drive and block the hole. Tape up the vent well and put a tarp under the dolly/transmission as you work. it's a greasy mess. Like 914sixer said, use a putty knife to get all the thick junk. Then I used 4 cans of brake cleaner to loosen it all up. More expensive than oven cleaner, but it seems to work quicker. Then I removed the stub axles to get at the tight spots and used a steam cleaner to do the final cleaning (HF has em for under a hundred bucks and it's my new favorite tool). Finally I painted with Alumi-blast and it turned out great. There's some disagreement as to how much paint (especially silver) contains heat, but I figure it isn't significant and protecting the box from the elements is probably better net-net. If breaking the whole tranny down, I might consider having it dipped to save myself the greasy mess and my wife complaining about stains on the driveway;) Sure looks nice! |
914_7T3 |
Jan 18 2018, 10:52 AM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Pressure wash, remove internals and then media blast in a tumbler.
No paint or spray coatings of any kind will be required on the finished product. The magnesium pores will close and the case will darken again over time as when it was new. FWIW Ian's case looks great, but I'm into originality so its all a matter of preference. |
914 RZ-1 |
Jan 18 2018, 10:55 AM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I used this stuff:
https://www.lowes.com/pd/Crown-128-fl-oz-Se...Remover/3024382 I brushed it on, let it soak and then pressure-washed the outside. It took me 6 times before I got everything off. I also chipped off the heavy deposits with a chisel, used a wire brush (hand and on a drill) and got in the nooks and crannies with a pick. I did mine in a dirt area in my backyard. Then I scooped up the dirty dirt and put it in the trash. |
VaccaRabite |
Jan 18 2018, 11:13 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Don't do what I did and soak it in a big metal farm tank sealed up with butyl using kerosene as a cleaning agent.
Oh, the case got clean. But the Kero ate the butyl sealing up the tank and stripped a layer of asphalt down my driveway. It was bad. It was also the day before I was supposed to fly to Cancun for a week. My driveway looked like ass for a few months till the sun bleached the asphalt all the same color again. Zach |
NeunEinVier |
Jan 18 2018, 12:47 PM
Member Group: Members Posts: 110 Joined: 24-December 15 From: In front of the smoke. Member No.: 19,488 Region Association: None |
Never tried oven cleaner, but Gunk Engine Cleaner stuff works pretty good, especially if you do it on a hot day in the sun. Spray it on and let it sit for 15 minutes then use a stiff plastic brush and a tub of really hot water to loosen and much grime as possible, and hose it off.
Wish there was a good way to catch the oil and grime. Can't be good for the environment rinsing that stuff into the lawn or storm drain. Going to a professional steam rack is probably the most environmentally friendly plan. |
Mblizzard |
Jan 18 2018, 02:37 PM
While your choice of clearer/solvent is up to the individual, as others have noted heat works wonders. I set my trans in front of just a standard electric heater for several hours prior to soaking with a non-toxic citrus based clearer. Let soak about 20-min and used a nylon brush to work it in. After it is clean, use a fine brass wire wheel brush to do a final clean The results are astounding. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:44 PM |
