FS 1974 1.8 Phoenix Red driver $10,500, Registered, insured, 5 lug, FG flared |
marksteinhilber |
Feb 7 2018, 05:45 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
Have ad up on local CL. https://orangecounty.craigslist.org/cto/d/1...6638637788.html
$10,500 with spare gearbox and uncracked oem dash, $9800 without Finishing up all the hard rust repairs. Hundred hours and many RD panels replaced, photos of repairs. Body stripped bare, etched, primed, Temporary paint. New interior and all new rubber seals. matching 1.8 running with orig L-jet, European Headers Wife says I can work on all her Dad's 912 and drive his green 914 Been Going to Coffee & Cars, etc. Fully Running & driving, fully registered. Corners like a go cart Clean title in my name. Original fuel injected 1.8 engine (Bosch L jetronic) 5 speed manual. Its been to a bunch of Coffee & Cars, even display at PCA concours a mile square park "Run with the 9-4-teeners!" Car is worth way more that asking price in all the new and working parts. A Driving Project about 85% done, should be worth 15 -20K when complete Great Father -son project with most of hard stuff done. I can complete additional work at less than shop rates. WHEELS 7 SUSPENSION: 5 lug conversion with reproduction fuchs wheels 15x7 front and 15x8 rear upgraded front suspension with new poly bushings, stiff front torsion bars, front anti-roll bar (sway bar) with adjustable drop links rebuilt rear trailing arms, new bearings, autocross stiff rear springs BRAKES: Upgraded front 320i brake calipers same size as 911, PMB rebuilt 914 rear calipers. 19mm master cylinder All new rotors, new brake flex lines Parking brake work excellent, all new parking brake cables BODYWORK: Car is back to original color Phoenix red L32K California car - All structural areas (Hell hole, inner longitudinal, & jack points), have been repaired and reinforced for track or autocross. Interior and exterior of longitudinals have "Engman" style kit sheet metal overlay Inner firewall has new sheet metal overlay for torsional rigidity New steel panels in right sail, & replaced steel front fenders New jack points both sides excellent condition steel rockers Both doors were also replaced with excellent condition doors from same year/no rust. All body panels, doors, and trunk lids have been stripped to bare metal, etched, primed, and currently have a base coat of L32K. Still some bodywork projects before paint remain to be done. INTERIOR All new rubber gaskets on doors, windows, targa, and trunks ($2000 worth of new rubber) New interior, including door cards, console, and reupholstered OEM seats ($1500 in new interior) Aluminum footboards behind pedals and for passenger stereo and speakers 914 carpet floormats Custom rearview visor mount mirror OEM rear view mirrors both sides ENGINE: European headers new throttle body & new throttle cable fuel tank cleaned and sealed new stainless steel fuel lines in tunnel & all new rubber fuel lines & filter fuel pressure guage in engine bay Engine pulls hard and starts immediately, good compression, engine has not been recently rebuilt,suspect worn valve guides Great candidate to build a 2056, a big 4 2258 cc, or swap in a Porsche 6 cylinder GEARBOX: 5 speed manual new rebuilt & powdercoated Bruce stone pedal set, all new bronze shift linkage bearings Tangerine Racing firewall spherical shift bearing Tangerine Racing clutch cable mount plate & new clutch cable new speedo angle drive gear and seals Spare gearbox comes with car as box installed is acting up in 3rd. ELECTRICAL: Optima gel battery New Bosch Alternator headlight units all reconditioned and working running lights reconditioned with LED bulbs in tail, turn, and brake lights LED dash gauges. Hella euro tail lenses ($400/pair) OTHER; rear trunk gas lifts to replace torsion springs, new Rennwest heim joint trunk hinge mounts Fiberglass front lip spoiler, Fiberglass rear GT fender flares. Front fender flares come with car flat tow bar mount plate under chin spoiler - can flat tow for long trips Project items still to do: 1. horns not working yet 2. fog lights restored and good, no power to front yet 3.4. gearbox has good synchros/no grinding, but sometimes pops out of third. 5. still need to swap new L front fender and repair edge of cowl by L fender 6. hidden small rust spot behind bottom of R tail light 7. right rear bumper mount needs alignment and trunk floor needs some love 8. a few new rubber seals are included, but waiting to go on after paint 9. Final Paint needed in Phoenix Red L32K, recommend 2 stage, color sand and clear coat. [attachmentid=658 399] Attached thumbnail(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:32 PM |
