| r_towle |
Feb 17 2018, 04:13 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Has anyone done testing to understand the Net difference between single and twin plug on a /4?
| mepstein |
Feb 17 2018, 04:25 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
A twin plug doesn't make power in it's self. It's mostly done on sixes to run higher compression. So it would be hard to compare apples to apples if the engines don't have the same compression ratio.
| ablesnead |
Feb 17 2018, 04:38 PM
Member ![]() ![]() Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
I had one of the first ones years ago ....used a datsun pickup distributor..the engine idled a lot smoother..sounded a lot different ....could not tell any power increase
| Mueller |
Feb 17 2018, 04:39 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Good question, i know on aircraft engines you can hear the difference when disabling one set when testing the magnetos while the motor is rumning.
There is a thread place where Jake made some comments about timing and such. |
| Elliot Cannon |
Feb 17 2018, 07:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
These guys rebuilt my heads for me. They can convert to twin plug if you want. I think they told me you can use a Nissan or Datsun distributor. Not sure which one. I'm also not sure if the expense would be worth it. (IMG:style_emoticons/default/biggrin.gif) http://www.europeanmotorworks.com/
| buz914 |
Feb 17 2018, 07:11 PM
Newbie ![]() Group: Members Posts: 26 Joined: 30-April 16 From: Florida Member No.: 19,952 Region Association: South East States |
And aircraft engines are low compression, air cooled engines.
Good question, i know on aircraft engines you can hear the difference when disabling one set when testing the magnetos while the motor is rumning. There is a thread place where Jake made some comments about timing and such. |
| Mueller |
Feb 17 2018, 07:51 PM
Microsquirt seems the easiest for twin plugging now that we csn run the low amp drivers.
| Mueller |
Feb 17 2018, 07:53 PM
And aircraft engines are low compression, air cooled engines. Good question, i know on aircraft engines you can hear the difference when disabling one set when testing the magnetos while the motor is rumning. There is a thread place where Jake made some comments about timing and such. More of a safety feature from what I remember, nice to have some redundancy way up there. |
| gms |
Feb 18 2018, 09:23 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,738 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest
The 914/4 combustion chamber is a modified wedge style design which compressions (squashes) the air-fuel mixture toward the spark plug. Adding a second plug may have some advantage but not as much as the 911s hemispheric combustion chamber which benefits from 2 points of ignition.
There was a local guy who did the twin plug 914/4 heads back in the ‘90s his name was Morrison and he was in Aurora IL. ![]() |
| peteyd |
Feb 18 2018, 01:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 743 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Here is a build thread of a 2.8L twin plug
http://www.shoptalkforums.com/viewtopic.ph...n+plug#p1200260 |
| Krieger |
Feb 18 2018, 01:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,847 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Sounds like one more place for the heads to crack for not much gain.
| gereed75 |
Feb 18 2018, 01:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
Agree with Glenn. The 911 benefits because of combustion chamber shape and typical high domes in higher compression builds. Allows for better timing with a more efficient burn on both “sides” of the chamber.
Not sure the same benefits will happen in a 4 cylinder. Used in aircraft engines for redundancy and also because the combustion chamber is large (360 cubic inch four banger). The second plug yields a faster and more complete fuel burn by starting two flame fronts. Again not sure that will benefit a smaller four in the same way. No testing, just anecdotal, but with dubious benefit probably the reason no testing (and relatively few applications) have been done. |
| peteyd |
Feb 18 2018, 01:42 PM
I have always been interested in a twin plugged engine. I have done quite a bit of research and it seems that the consensus is that only "big engines" like 2.3L or greater benefit from twin plug. At least this is what one engine builder says. But sometimes I feel like he may say things just to dissuade us from doing them.
I was also interested in roller lifters, and he was very discouraging for people to head down that road as well. Pete |
| 914work |
Feb 18 2018, 05:05 PM
Member ![]() ![]() Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
The 914/4 combustion chamber is a modified wedge style design which compresses (squashes) the air-fuel mixture toward the [existing] spark plug. Adding a second plug may have some advantage but not as much as the 911's hemispheric combustion chamber which benefits from 2 points of ignition. This is where a skilled welder/machinist a flow bench, a mule motor & significant time would prove beneficial. The ROI...well Im sure that is purely subjective. The old joke/riddle: "How do you make a small fortune?" comes to mind. The vendor to which Peteyd refers claims to have "built" multiple permutations until finding the best combination of mods. I think that Len's contributions cant be understated here. (IMG:style_emoticons/default/sunglasses.gif) |
| horizontally-opposed |
Feb 18 2018, 05:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
European Car (RIP), maybe when it was still VW&Porsche, magazine did a story on a black 914 with chrome five-lug Fuchs, the "PORSCHE" side valances, and...a twin-plug Type IV engine—noting it ran noticeably smoother and sounded better with dual ignition. Same car may have been supercharged at some point?
I believe it popped up for sale recently, now with six cylinders. Not sure what to take from that, if anything. |
| 914work |
Feb 18 2018, 07:11 PM
European Car (RIP), maybe when it was still VW&Porsche, magazine did a story on a black 914 with chrome five-lug Fuchs, the "PORSCHE" side valances, and...a twin-plug Type IV engine—noting it ran noticeably smoother and sounded better with dual ignition. Same car may have been supercharged at some point? I have that issue somewhere. (IMG:style_emoticons/default/smile.gif) You gotta go back to the motivations for modding the base motor to begin with. Goals: more performance, smother running, alternate exhaust dynamic... retention of *quasi* stock configuration How much is that worth~ ? Sure you can yank it & Six it. Some folks just like to do it the ..unconventional way |
| r_towle |
Feb 18 2018, 07:27 PM
So, lots of cool responses.
I am curious if twin plug, large displacement enables slightly more HP, and a better more efficient motor. I think these motors were something like 35% efficient. Certainly a less costly road to travel versus a /6 |
| ablesnead |
Feb 18 2018, 07:29 PM
..My car was in Volkswagen Porsche way back in the eighties ...one of first twin plug type 4's RPM in Daytona did it...
| Chris914n6 |
Feb 19 2018, 01:00 AM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
The dizzy cap is from an 80s Datsun 720 pickup with the z24 engine.
I don't think it's worth the expense with the fuel/spark options we have today. |
| jd74914 |
Feb 19 2018, 06:09 AM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,875 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
So, lots of cool responses. I am curious if twin plug, large displacement enables slightly more HP, and a better more efficient motor. I think these motors were something like 35% efficient. Certainly a less costly road to travel versus a /6 Not sure how much you would gain (perhaps a percentage or two max I bet). I think you might end up using the second plug to compensate for the decrease in efficiency with a much larger chamber? They definitely aren't 35% efficient. That's F1 efficiency territory (no KERS), and higher end than pretty much any production cars. |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:07 PM |
