front sway bar bushing, to compress or not to compress |
iankarr |
Feb 19 2018, 09:06 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
I'm finally in the home stretch of my front end winter projects. Lots of videos coming soon. Seems the rubber sway bar bushing is sitting proud of the back edge of the mount. The front ridge is just over the front opening, which appears to be as designed. Does the rear just get compressed when everything gets bolted up...or should I be looking for a different, shorter bushing? |
toolguy |
Feb 19 2018, 09:24 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
You are correct. . it will compress and form a tight solid fit on the sway bar when the mounting bolts are tightened . Use some rubber lube, dish soap etc and it will easily all slide together in the proper place.
iankarr |
Feb 19 2018, 09:33 PM
thanks man.
Lo-Fi Version | Time is now: 3rd June 2024 - 05:37 AM |
