transmission question, removing synchro hub from gear |
ws91420 |
Jun 3 2005, 02:25 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Is there anyway to do this w/o the special tool? Do you need a special tool to install it as well?
Demick |
Jun 3 2005, 02:41 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
The synchro rings themselves need no special tool - except for a GOOD set of c-clip pliers.
But if you are talking about removing the dog teeth from the gear - that's a different story. I've done it on 1st gear without any special tools, but any other gear is near impossible and probably requires the special porsche tool. Demick |
Cano |
Jun 3 2005, 02:54 PM
Member Group: Members Posts: 110 Joined: 29-September 04 From: Goshen, KY Member No.: 2,854 Region Association: None |
IF you are replacing the dogteeth (why else would you remove it from the gear?) you do not need the special tool. I was able to cut/grind my 2nd gear dogteeth almost all the way off without touching the gear. Then it was just a matter of using a chisle (sp?) and hammer to get it the rest of the way off.
To install the new one, I just used a block of wood and a 3 pound hammer to bang it on. JUst make sure it goes on evenly and fully. |
ws91420 |
Jun 3 2005, 03:19 PM
Yes if I wasn't clear I am replacing the dogteeth. Cutting sounds good but I dont have access to a cutoff wheel at this time.
Lo-Fi Version | Time is now: 23rd May 2024 - 12:55 PM |
