> Rear trunk cable release, Anyone making them?
Mowog4
post Mar 11 2018, 08:16 PM
I am looking for a rear trunk cable release kit, is anyone making them anymore?
Replies(1 - 19)
98101
post Mar 11 2018, 09:56 PM
Michael in Seattle
QUOTE(Mowog4 @ Mar 11 2018, 07:16 PM) *
I can't say I'm having a great experience with mine:
http://www.914world.com/bbs2/index.php?showtopic=325756
Mowog4
post Mar 12 2018, 12:37 AM
QUOTE(98101 @ Mar 11 2018, 08:56 PM) *
That is a challenge. Mine has no reflector, but the hole was welded shut by the PO.it does look clean, but I don’t trust the electric solenoid.
Steve
post Mar 12 2018, 12:40 AM
I upgraded my solenoid to an industrial spal solenoid. No problems now!!
Mowog4
post Mar 12 2018, 07:38 AM
QUOTE(Steve @ Mar 11 2018, 11:40 PM) *
Any part number? Where did you get it?
Thanks
Ed
dr914@autoatlanta.com
post Mar 12 2018, 09:11 AM
We make the rear update kits with electric release, but Mark should be making the manual release
Mark Henry
post Mar 12 2018, 07:06 PM
that's what I do!
QUOTE(Mowog4 @ Mar 12 2018, 02:37 AM) *
I think 914rubber has them or was making them at one time.
With the solenoid some would drill a small hole with a grommet in the trunk floor and run an emergency pull wire under the car.
Steve
post Mar 12 2018, 08:21 PM
QUOTE(Mowog4 @ Mar 12 2018, 06:38 AM) *
Thanks
Ed
https://www.amazon.com/gp/aw/d/B009OBPHSG/r...&ref=plSrch
Mikey914
post Mar 13 2018, 10:05 AM
The rubber man
These can be made. and I think with existing parts.
https://900designs.zoeysite.com/search/?q=pull
I had one member contact me about this.
I would think a cable could be routed along the wiring for the tail lights and wind up with a base and pull discretely mounted on the back side of the trunk. The only problem is I do not have this so I can't really work the problems out.
Mark
Would love to work with someone to prototype and document the install. I know others have bought these and done so, but it would be less expensive to have a "kit".
restore2seater
post Mar 13 2018, 02:48 PM
Future 914 copilot.
QUOTE(Mikey914 @ Mar 13 2018, 11:05 AM) *
Not sure of the exact meaning of discretely mounted on the back side of the trunk.
Are you referencing inside the passenger compartment or the engine compartment?
If it would be possible to locate the pull handle near the pull for engine lid, I would be interested in a kit. Maybe start a GB post to check interest.
Mowog4
post Mar 13 2018, 05:23 PM
QUOTE(Mark Henry @ Mar 12 2018, 06:06 PM) *
I will run the cable through the floor to augment by electric solenoid, thanks
Mowog4
QUOTE(Steve @ Mar 12 2018, 07:21 PM) *
Thanks
Ed
Thanks Steve, just ordered one.
Mikey914
post Mar 13 2018, 05:27 PM
The rubber man
These could really be mounted anywhere you want. I can make a bolt that is machined through for the bade like I did with the GT headlight release. It can be backed by a large washer and would easily make this work.
I think that the electrical release issues I have heard of in the past were more of a ground not making good contact, so this was a if all else fails option that required no electricity.
Mowog4
post Mar 13 2018, 08:14 PM
QUOTE(Mikey914 @ Mar 13 2018, 04:27 PM) *
Sign me up, put the pieces together and send me a paypal. I will piece it together. I think the electric solenoids if they are set up correctly should be pretty reliable, but it is nice to have an insurance policy. I will replace the solenoid with the SPAL unit Steve described.
Coondog
post Mar 13 2018, 08:28 PM
QUOTE(Mowog4 @ Mar 13 2018, 07:14 PM) *
Please post pics when your done. I would love to remove my truck lock.
FUEL14
post Jul 10 2020, 07:54 PM
Region Association: Australia and New Zealand
Hi, I'm resurrecting this thread to see if there is a kit solution out there now. I'm looking for a rear trunk release kit asap.
Thanks, Luke.
post Jul 11 2020, 12:38 AM
Michael in Seattle
QUOTE(FUEL14 @ Jul 10 2020, 06:54 PM) *
Thanks, Luke.
I drove my 914 for the first time in a while today. I left the roof in the apartment parking garage because my rear trunk hasn't opened for a year or so.
Looks cool with the rear reflector though.
wes
post Jul 11 2020, 01:27 AM
wes
I have the electric solenoid I also have a new rubber and I found the release works as long as someone lightly pushes down on the trunk lid. Of corse most of the time I drive alone.
tlehman914
post Jul 27 2025, 11:05 AM
QUOTE(FUEL14 @ Jul 10 2020, 08:54 PM) *
Thanks, Luke.
Hi all,
I’m bringing this topic back to the top in hopes of tracking down a rear trunk release kit—ideally the Engman-style mechanical pull kit.
I’ve eliminated the factory push-button by replacing that entire section with custom metalwork (similar in shape to the PORSCHE reflector, but all steel and blended flush with the trunk and tail lights). So now I need a clean, internal way to release the trunk. I’ve searched extensively and haven’t been able to find an off-the-shelf solution from 914Rubber, JWest, etc.
If anyone:
• Has an Engman kit for sale
• Knows where to get one
• Would be willing to lend or share dimensions/photos so I can reverse engineer and fabricate my own
…I’d really appreciate it.
Thanks in advance!
tlehman914
post Jul 27 2025, 11:07 AM
Hi all,
I’m bringing this topic back to the top in hopes of tracking down a Rear Trunk Release kit —ideally the Engman-style mechanical pull kit.
If anyone:
Thanks in advance!Attached Image
- Lo-Fi Version Time is now: 2nd April 2026 - 12:01 PM
