No turn signals, hazard light switch perhaps? FIXED! |
John90290 |
Mar 14 2018, 08:07 AM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
So been going through the new to me 1975 1.8l and noticed I did not have turn signals or a hazard light. Replaced the relay, nothing. Decided to pull the hazard switch and it came out in pieces with the ground side not even connected. . I assume that like old school Christmas lights, if the hazard switch is not connected then the turn signals will not work bc they are working off the same relay? I’ve found wiring diagrams for the proper hook up of the switch and will try to re assemble the one i have but not sure if there are pieces missing or not. Got a new used one on the way just in case.
Any insight would be appreciated. John. (IMG:style_emoticons/default/biggrin.gif) |
Spoke |
Mar 14 2018, 08:46 AM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Hazzard switch won't cause the turnsignals to not operate. Check fuses 9 and 11.
jkb944t |
Mar 14 2018, 11:11 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
If the fuses are ok then it could be a bad flasher relay which is located behind the instrument panel near the fuse panel. You will probably need to remove the fuse panel to get to the flasher relay.
Jeff B |
John90290 |
Mar 15 2018, 10:10 AM
If the fuses are ok then it could be a bad flasher relay which is located behind the instrument panel near the fuse panel. You will probably need to remove the fuse panel to get to the flasher relay. Jeff B Checked and replaced fuses and flasher, still no signal or hazard (IMG:style_emoticons/default/sad.gif) could it be the turn signal switch on the column? -John |
John90290 |
Mar 15 2018, 07:25 PM
If the fuses are ok then it could be a bad flasher relay which is located behind the instrument panel near the fuse panel. You will probably need to remove the fuse panel to get to the flasher relay. Jeff B Checked and replaced fuses and flasher, still no signal or hazard (IMG:style_emoticons/default/sad.gif) could it be the turn signal switch on the column? -John Also , what is this relay in the back truck? |
John90290 |
Mar 15 2018, 07:26 PM
If the fuses are ok then it could be a bad flasher relay which is located behind the instrument panel near the fuse panel. You will probably need to remove the fuse panel to get to the flasher relay. Jeff B Checked and replaced fuses and flasher, still no signal or hazard (IMG:style_emoticons/default/sad.gif) could it be the turn signal switch on the column? -John Also , what is this relay in the back trunk? |
John90290 |
Mar 16 2018, 04:39 PM
FIXED!
FYI. It was the hazard light switch. Mine was in pieces and the turn signal did not work. Bought a new used one and Mátales and it works like a charm. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:18 AM |
