ryancr500 |
I'm new here ... Group: Members Posts: 0 Joined: 25-March 18 From: Tsawwassen BC Member No.: 21,998 Region Association: Canada ![]() |
I’m looking to buy a good set of used dual carbs for my 74 2.0 914. Car currently has a single carb that isn’t working too well. I would prefer Weber or Dellorto carbs. Set must be complete including intakes. Please let me know if you have anything. Would need to be shipped to Point Roberts,WA 98281
Email me at keeferhawks1@gmail.com Ryan |
KevinW |
Newbie ![]() Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest ![]() ![]() |
Ryan, there is a pair for sale on Milwaukee WI Craigslist
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Did you see these? http://www.914world.com/bbs2/index.php?showtopic=326501
I tried a single progressive carb on a 914 and VW bus with horrible results. Switched to 34ICTs and was very happy with them. |
MikeM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada ![]() |
Ryan...join our Facebook group...Porsche 914 Canada.
Mike |
ryancr500 |
Did you see these? http://www.914world.com/bbs2/index.php?showtopic=326501 I tried a single progressive carb on a 914 and VW bus with horrible results. Switched to 34ICTs and was very happy with them. I did see these. Was considering them. Would these perform as well as 40 or 44 idf? |
bbrock |
Did you see these? http://www.914world.com/bbs2/index.php?showtopic=326501 I tried a single progressive carb on a 914 and VW bus with horrible results. Switched to 34ICTs and was very happy with them. I did see these. Was considering them. Would these perform as well as 40 or 44 idf? No, but way better than a single carb so it would be a good budget option. I ran them on stock 1.7L engines with stock cams and was satisfied. More reliable than the aging FI they replaced, but not as good of performance although I never bothered to try to tune them and ran jetting that came out out of the box. |
type2man |
Member ![]() ![]() Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States ![]() |
Best carbs to run are either 36 or 40 Dellortos. Second choice would be 44 Webers. I would never run 34 ICT's. They are not made for any performance engines out there over 1700 cc's. They are only good for a 1600 beetle engine. They will choke down your 2.0 just as bad as a progressive.
AMac |
Newbie ![]() Group: Members Posts: 6 Joined: 9-May 18 From: North Vancouver Member No.: 22,106 Region Association: Canada ![]() |
I’m looking to buy a good set of used dual carbs for my 74 2.0 914. Car currently has a single carb that isn’t working too well. I would prefer Weber or Dellorto carbs. Set must be complete including intakes. Please let me know if you have anything. Would need to be shipped to Point Roberts,WA 98281 Email me at keeferhawks1@gmail.com Ryan Andrew here. I have 40 Dells from my 912e. Running fine when I removed last year. I am in vancouver BC. Cheers, |
AMac |
I’m looking to buy a good set of used dual carbs for my 74 2.0 914. Car currently has a single carb that isn’t working too well. I would prefer Weber or Dellorto carbs. Set must be complete including intakes. Please let me know if you have anything. Would need to be shipped to Point Roberts,WA 98281 Email me at keeferhawks1@gmail.com Ryan me and my 40mm Dells are only 40km from you. Im in North Vancouver. Complete with hardware, manifolds and linkage. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:32 AM |
