WTB: 914-6 Driver's Side Heater Flapper Valve |
db9146 |
Mar 31 2018, 10:42 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Anyone have such for sale?
Dee DB9146 |
914Sixer |
Apr 1 2018, 05:23 AM
914 Guru Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Take a stock heater flap valve and use a step drill to make you one.
mepstein |
Apr 1 2018, 05:51 AM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
My modified flapper from a four. I used a 1 1/2" hole saw.
Attached image(s) |
db9146 |
Apr 1 2018, 08:01 AM
Yes, I did that to a new -4 yesterday that was tabbed and welded. IT does seem that the angle for the hose off to the long should be at a slightly different angle, though.
mepstein |
Apr 1 2018, 08:08 AM
Yes, I did that to a new -4 yesterday that was tabbed and welded. IT does seem that the angle for the hose off to the long should be at a slightly different angle, though. I'm sure you are right about the angle. There are so many six parts that are just slightly different than their corresponding four parts. At least you can make the piece work for you until you find the right one. |
Steve |
Apr 1 2018, 08:42 AM
914 Guru Group: Members Posts: 5,620 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I just bolted up 914-4 flappers to my six heat exchangers 20 years ago and never had a problem. I’m using the same 914-4 flappers today with Bens heat exchangers.
Lo-Fi Version | Time is now: 17th June 2024 - 01:08 PM |
