For Sale!, Miscellaneous 914 parts and accessories |
Pdr1787 |
May 2 2018, 02:05 PM
Sneaky Pete Group: Members Posts: 55 Joined: 8-September 09 From: Lakewood, California Member No.: 10,779 Region Association: Southern California |
I might be selling some wiring not sure yet (with plugs) but this is what I'm willing to let go of or don't need. Also willing to negotiate.
Tail shift Linkage (allparts to firewall) 80 Tail shift Transmission 250 Tail shift cover (trans and firewall) 40 Tail shift Motor mount Brace and crossmember 50 1.7l heat exchangers 150 Passenger side heater control valve and elbow to heat exchanger. 60 Side shift linkage to transmission. 200 2 Solex 31 Carbs. probably should be rebuilt and Intake Manifolds 50 Sold 12 volt Bosh coil used for only 300 miles 40 2 Voltage regulators 100 for both Bosh original distributor with vacuum 50 Mechanical advance distributor chrome 009 80 1.7l rods 80 for 4 2.0l type 4 cylinders 80 Heater fan blower 80 8' passenger footwell sub and box. 100 SOLD original speaker grills 40 1.7l ecu 120 intake and exhaust valves/ high rev double springs (new) for 2.0l porsche heads. 150 SOLD |
jtprettyman |
May 2 2018, 02:33 PM
Rust Bucket Owner Group: Members Posts: 109 Joined: 5-May 15 From: Murfreesboro Tennessee Member No.: 18,707 Region Association: South East States |
I'm in for the carbs and manifolds! PM coming.
JeffBowlsby |
May 2 2018, 07:04 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Exactly what wiring?
JeffBowlsby |
May 2 2018, 07:05 PM
Pdr1787 |
May 2 2018, 07:35 PM
mxkinn01 |
May 2 2018, 07:46 PM
Member Group: Members Posts: 231 Joined: 18-June 17 From: Las Vegas, NV Member No.: 21,195 Region Association: Southwest Region |
How about pictures of the speaker grills? If they are in good shape I'll take them.
Pdr1787 |
May 3 2018, 04:19 PM
Here is the subwoofer and speaker grills
Attached thumbnail(s) |
mxkinn01 |
May 3 2018, 07:11 PM
Thank you for the pictures of the speaker grills. I will pass, as mine are in better shape.
Thanks Mike |
JeffBowlsby |
May 3 2018, 07:30 PM
Exactly what wiring? The wiring harness that comes out of the firewall and goes to the voltage regulator and what not That’s a small potion of the main chassis harness. It’s not a separate harness. Don’t cut any wiring, just remove it in one piece and sell it complete. |
Driver174 |
May 3 2018, 11:18 PM
Member Group: Members Posts: 106 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
What brand of cylinders? and how much for four shipped to 89119? Thanks, |
Pdr1787 |
May 10 2018, 03:10 PM
Exactly what wiring? The wiring harness that comes out of the firewall and goes to the voltage regulator and what not That’s a small potion of the main chassis harness. It’s not a separate harness. Don’t cut any wiring, just remove it in one piece and sell it complete. Do you have any tips on wire harness removal before I pull it out? |
JeffBowlsby |
May 11 2018, 05:01 PM
Don't cut anything.
Remove the plastic connectors/covers where needed - 14pin, headlights, etc. Don't cut anything. Use non-oil based lube if needed in the center tunnel - KY jelly. Don't cut anything. |
Pdr1787 |
May 12 2018, 11:01 PM
Transmission picture
Lo-Fi Version | Time is now: 6th June 2024 - 02:32 PM |
