window crank...which one?, broken crank again....siilly inexpensive part but need the right one |
frankieshooz |
May 3 2018, 09:24 PM
Member Group: Members Posts: 83 Joined: 23-September 14 From: Mill Valley, CA Member No.: 17,945 Region Association: Northern California |
well my drivers side window crank broke again...and I just noticed the passenger side one does not match (cover is slightly different) so I know this is a silly question as it is such an inexpensive part but who makes the best replacement and most closely to original cover design?
914Sixer |
May 3 2018, 09:30 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Go over to theSamba.com and find some original German ones. The Brazil ones are not so hot.
mepstein |
May 3 2018, 09:33 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Lube up all the sliding and moving parts (remove the door cards) when it slides easier, less pressure on the handle.
Pretty much true for the rest of the car as well. |
Tom_T |
May 4 2018, 09:06 AM
Auto Atlanta, Sierra Madre, Stoddards, Einmalig, & others carry them.
Buy 2 now so that they match, & put the odd one in your glovebox for a spare in the emergency. As Mark said - make sure that the crank, guides, regulator, etc. are cleaned then relubed with clean grease so they work less hard. If you look at the SMC ones on the page linked below, the chrome shank one was used 70-72 & some early 73s, the thin black shank was 73-74 & the fat shank was 75-76 MYs IIRC (there was probably some inter-MY mixing on the last 2 types as well) - contrary to what they list no there. And they would've tracked with the VW change over MYs as well, & they're basically VW parts, so you can find them at some VW parts houses too. FYI with pix - http://www.sierramadrecollection.com/914-9...or-Panels-c957/ (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Mikey914 |
May 4 2018, 10:47 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We have them as well. And a few other parts others dont have.
https://shop.914rubber.com/searchquick-subm...keywords=Window We actually make the rollers for the scisor mechanism. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 06:11 PM |
