> Not tooting my own horn, Fault between switch and relay.
worn
post May 6 2018, 06:11 PM
can't remember
Hi folks. It may not help, but I figure the horn is a last ditch method of avoiding a collision. But my ‘72 horn wire in the steering column has no continuity with the relay. I have had the whole works out of the car but I don’t remember how it is routed. Does the wire go continuously to the relay or maybe there are connections? Any help will be appreciated. Power to the relay works, the horns can be driven by shorting the relay, still no connection between any relay pin and the wire to the switch. So of course grounding the switch gives nada.
Replies(1 - 2)
jcd914
post May 6 2018, 06:55 PM
Per the wire diagram it is continuous straight to the horn relay (terminal 85).
Brown wire with white stripe.
The switch provides a ground for the relay engagement circuit.
Jim
worn
post May 6 2018, 08:10 PM
can't remember
QUOTE(jcd914 @ May 6 2018, 05:55 PM) *
Jim
Thanks. Must be either a break or failure at a connector. Wish it was simpler.
- Lo-Fi Version Time is now: 3rd June 2024 - 10:08 AM
