Holy Moley!, Anyone else see what FI cost now! |
Engman |
Jun 9 2005, 01:40 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
So I was looking thru the Bird Board at Fuel injection componets and I see
Fuel Injector, 4 Per Car, 914 2.0 (1973-74), Each 0-280-150-019 $210.10 Whoa! Two years ago these were like $89 - now they are over $200! Anyone know why? M |
ArtechnikA |
Jun 9 2005, 01:50 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
1) Porsche is making a buttload of money in Euro float
2) Because They Can |
Root_Werks |
Jun 9 2005, 01:53 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
(IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) I have noticed the same thing. Some stuff is NLA too. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
drgchapman |
Jun 9 2005, 01:54 PM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
Buy 'em used, have 'em tuned up at the injector shop. So many guys switching to carbs...they come up.
spare time toys |
Jun 9 2005, 01:59 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
Just an off the wall question. Has any ony checked into ford injectors? IIRC the 928 guys have found ford injectors that work on the 8s'. They are also using ford truck motor mounts as a replacement. Its like $80 for a pair verses a left nut for each one.
Joe Ricard |
Jun 9 2005, 02:05 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
GEEZ I thought you were on my Holy moly thread.
I would imagine if you could match the flow characteristics it would work. ie. 19 lb 24lb or 32 lb injectors common ford units. If you had a closed loop system it would be easier as the computer would fine tune with pulse width. D-jet just sprays on curve of RPM, throttle position and vacuum. |
greg.treadway |
Jun 9 2005, 02:10 PM
914 Nut Group: Members Posts: 282 Joined: 16-December 04 From: Marietta, GA Member No.: 3,295 |
I hope people are not switching to carbs!
These injectors should be $185.00/each and they do continue to go up. You can always get rebuilt ones to save a little. (IMG:http://autoatlanta.net/itemgraphics/7457-1.jpg) |
Dave_Darling |
Jun 9 2005, 03:24 PM
Ouch! I remember when they were $60 each. From us. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Most modern injectors will not fit the intake correctly. Most of them nowadays have a different end to them, and they use different seals. You could probably make it work with some machining... You'd also have to fabricate a way to hold the injectors in place and get fuel to them; most nowadays get sandwiched between the fuel rail and the manifold and don't have any separate way to fasten them. (Talk to the Megasquirt 914 guys; several of them have figured out which injectors can fit and how to make them fit.) ...That's in addition to making sure the flow numbers and the electrical characteristics match the stock injector's... Sounds like an interesting project, but probably not cost-effective. Yet. (Of course, if someone does such a project then they'll have a real leg up when the stock parts get too $$$ to replace.) --DD |
ArtechnikA |
Jun 9 2005, 03:50 PM
it'd be cool if it did that, but in fact, D-Jet knows only vacuum and rpm. the TPS is used only as an accel pump kludge... |
lapuwali |
Jun 9 2005, 03:59 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
The hose-barb style injectors haven't been used by any OEM in quite some time. There's a ready supply of older D-Jet injectors (I have 8 sitting in my garage, I'm sure others have even more), and cleaning them is usually sufficient to make them work like new.
New injectors in the O-ring style (O-ring mounts on both ends) are readily available new in a wide variety of sizes for as little as $30 ea. Fitting these to a D-Jet engine would require actual fuel rails, some plumbing to connect them, and MAYBE a bit of work on the runners, plus some way to secure the fuel rail (which also secures the injectors). If it's any consolation, GPR lists the 2.0 injectors at $180 ea. |
Mueller |
Jun 9 2005, 04:00 PM
I used the factory 1.8 and 2.0 injectors.....nothing special (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
fiid |
Jun 9 2005, 05:17 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
I used stock 1.7 injectors.
I was wondering if the 1.7 injectors are sufficient to support a 2 litre with aftermarket injection management. This might help aleviate (sp?) some of the squeeze on the 2l units. I think it would be hard to get this to work with a d-jet tho. |
lapuwali |
Jun 9 2005, 05:38 PM
Yes. The 1.7 and 2.0 injectors are both huge for the engines they're attached to. A 2.0 with 1.7 injectors and PEFI would be a lot easier to tune near idle, yet they'd still flow plenty for top-end power. |
Ray Warren |
Jun 9 2005, 07:42 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
I am using 1.7L injectors on my 2.0L with aftermarket FI. It works and idles very good. I think it would be even better if the injectors were smaller than they are. If you do the math from an "injector flow rate chart" the 1.7L injectors are good for about 50HP per cylinder. |
ppickerell |
Jun 9 2005, 07:46 PM
914 addicted Group: Members Posts: 1,679 Joined: 14-October 03 From: Pleasanton, CA. Member No.: 1,246 |
Herr Mueller can draw this up in cad, and I am positive I can make SERIOUS coin at $180 each. Hello early retirement.
ppickerell |
Jun 9 2005, 07:48 PM
Ha, half that has most of our motors covered. |
ppickerell |
Jun 9 2005, 07:49 PM
JeffBowlsby |
Jun 9 2005, 07:50 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hey Ray, I see you are using SDS on a 2.0L.
Have you posted your fuel maps anywhere on this site and if not, would you share your SDS settings? |
914rrr |
Jun 9 2005, 09:02 PM
Senior Member Group: Members Posts: 1,835 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
According to an Allen Institute Bosch fuel injection training manual, the following cars used D-Jet injection: some 75 thru 80 Cadillac, Mercedes w 3.5L to 70, 4.5L all, Saab 99E, Volvo 1800E, 1800ES, 142, 144 & 164E. Possibly some donors for injectors, etc.
Mark Henry |
Jun 9 2005, 09:25 PM
Ray is running with a narrow band AFM, bet you any money your running rich Ray... From an ol' narrow band guy with a new wideband (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) I've seen his maps...they look about right. PEFI is great...I'm running a stock 1.8 on 2.0 injectors right now with no issues. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:53 AM |
