bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
What is the proper gauge wire do I need to use when replacing the oil temp wire up to the dash? Thanks.
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
Since it is just the variable resistance of the sender to ground, the wire carries very little current.
Stock Oil temp wiring id 0.5mm which is smaller than 20 gauge wire. I would probably use 16 gauge wire because it is a little stronger and wil survive under the engine a little better. Jim |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,833 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I'll 2nd 16 - 20 gauge.
bandjoey |
Thx
Lo-Fi Version | Time is now: 16th July 2025 - 04:25 PM |
