Need Wheel Help, Fuchs 16x7 (911 & 951) |
seanery |
Jul 12 2003, 02:26 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I have a bunch of Fuchs and a friend of mine in LA is looking for some 16x7's. I want to make sure that he can use them before I officially offer them to him and set a price.
I have 2 of each of the following: P/N 911631010 [44] (on paddle 1) AS1062 (on paddle 1) FCO (paddle 3) [2385] (paddle 5) inspection numbers (paddle 2) size NO ET info (paddle 4) --------------------------- P/N 9513621 [15] (paddle 1) AS1062 (paddle 1) FCO (paddle 3) [3285] or [8Z85] (paddle 5) inspection numbers (paddle 2) ET 23 (paddle 4) There is a difference in the lug nut mounting hole (pics soon) similar to the difference between 8's and 9's. Does anyone have any more info on these? He wants to put them on his 914 2.7 -6. He is currently running 15x7 & 8 (I believe). Does anyone know the value? |
Jeroen |
Jul 12 2003, 04:04 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
The P/N 9513621 [15] are 944 fuchs wheels.
IIRC the inner diameter of these is slightly larger compared to the 911 fuchs, so they will take bigger brake calipers. Not sure, but you could easily measure and compare the two The 8x16 944 fuchs also have a ET of 23, compared to the 8x16 911 fuchs, which have an ET of 10 Supposedly the 8x16 944 fuchs are popular with the 911 crowd because it allows wider tires on the front (higher ET means more backspacing) 7x16 fuchs for both the 911 and 944 have the same ET of 23 (which you already mentioned) cheers, Jeroen |
seanery |
Jul 12 2003, 05:02 PM
Thanks Jeroen,
I'm keeping my 8's to use on the front of the blue car (assuming it ever gets done). So, he should be able to use both, then, huh? Maybe put the 951 wheels up front and the 911 in back? |
Jeroen |
Jul 12 2003, 05:16 PM
Hey Sean,
Since both the 7" 911 and 7" 944 fuchs have the same ET, it wouldn't matter which you put up front or in the rear. With the 8's it would... cheers, Jeroen |
Jeroen |
Jul 12 2003, 05:17 PM
Oh, can you check/measure the differences between the 944 and 911 fuchs?
I'm curious cheers, Jeroen |
seanery |
Jul 12 2003, 05:18 PM
I was thinking since you can fit a bigger brake inside the 951 wheel it may make more sense to do it up front (IMG:style_emoticons/default/confused24.gif)
Jeroen |
Jul 12 2003, 06:24 PM
Errr... yes, in that case it would
How big a brakes are you planning for though? cheers, Jeroen |
seanery |
Jul 12 2003, 07:08 PM
not my car, I'm not sure what size he has...just thinking ahead i guess.
seanery |
Jul 12 2003, 07:10 PM
here's some pics of the wheels.
951 lug bolt holes Attached image(s) |
seanery |
911 lug bolt holes (i know its fuzzy-I musta had andy's camera)
Attached image(s) |
seanery |
Jul 12 2003, 07:13 PM
951 wheel & lip
Attached image(s) |
seanery |
Jul 12 2003, 07:14 PM
911 wheel & lip
Attached image(s) |
seanery |
Jul 12 2003, 08:58 PM
OK,
I went out and measured some areas of the wheel...interesting results... 911 Horizontal Lip - 1" Vertical Lip - 1 1/16" Clear part of face - Angled Down Back of wheel to Face - 5 3/16" Front of wheel to hole for center cap - 1" 951 Horizontal Lip - 1" Vertical Lip - 1 3/16" Clear part of face - Flat Back of wheel to Face - 6 1/16"" Front of wheel to hole for center cap - 1/4" |
Jeroen |
Jul 13 2003, 07:56 AM
What do you mean by "Back of wheel to Face" ?
The differences look weird and I wonder why they did it Did you by any chance measure the inner diameters? cheers, Jeroen |
seanery |
Jul 13 2003, 08:07 AM
the back of the wheel to the face distance is the distance from the back edge of the inside inner lip to the front of the of the black area, the flat black area between the paddles. I did not measure the inside diameter, I'll do it today.
Lo-Fi Version | Time is now: 28th May 2024 - 01:11 PM |
