speaker installation |
db9146 |
Jun 19 2018, 03:01 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Several years ago, I bought some speaker pods that had never had speakers installed in them.
Currently, the car does use speaker pods but instead has rectangular speaker enclosures (a/d/s 200i), so my question is how do I remove the white "rivet-like" pins w/o damaging the pins or the pods? |
914Sixer |
Jun 19 2018, 03:12 PM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
They are the same white rivets used on the door sill molding. Take needlenose pliers and pull center out.
Rob-O |
Jun 19 2018, 06:49 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
I believe the white rivets are just placeholders. Once you pull them out and place a speaker in there a bolt and washer screws into where those rivets are. I suspect you know that but just in case!
db9146 |
Jun 19 2018, 07:38 PM
Thanks, that got them.
Anyone know the size of the screws? Seems like they might be M4 but they didn't seem to fit. |
Rob-O |
Jun 19 2018, 08:17 PM
I thought m6 but can’t remember. Got an ACE hardware nearby? Mine has a very good collection of metric nuts/bolts.
914Sixer |
Jun 19 2018, 08:30 PM
Try SAE. I think they were set up for the Motorola speaker kits.
Chris914n6 |
Jun 20 2018, 01:28 AM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
8-32 didn't thread. I'm fairly sure what I'm using is m4.
mankowski |
Jun 20 2018, 03:25 PM
Member Group: Members Posts: 128 Joined: 7-February 10 From: Portland, Oregon Member No.: 11,335 Region Association: Pacific Northwest |
Porsche part catalog lists the right side screws as 8 x 16 raised countersink and the left side screw as an 8 x 22 tapping screw.
steuspeed |
Jun 20 2018, 08:43 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Are you mounting 200i speakers in there? Post pics of your install please. Also, Are you adding a sub and amp?
Lo-Fi Version | Time is now: 29th May 2024 - 01:51 AM |
