| Cristi iftode |
Jun 28 2018, 12:52 PM
Newbie ![]() Group: Members Posts: 1 Joined: 28-June 18 From: Iasi,Romania Member No.: 22,270 Region Association: None |
(IMG:style_emoticons/default/screwy.gif)
Hi! I need Porsche specialist for help with one at base porsche engine . Made in France, for ultralight airplane jpx 4T 60A JPX, comany no longer exist. I need to improve power for this engine from maximal 65 hp at 3200 rot/min (propella limitation) to 80 hp. Now compresion is at 7.7. Please help me with calculation and proper complete rebild kit for my dream 80 hp. I want to improve my engine with efis or injection if is at humanoid price... For detail email me at ifcristian@yahoo.com or facebook cristi iftode I now, is not a Porsche car, but i like Porsche.is like one little airplane.Speed, fly... scuse me for offtopic. This is the engine: http://www.ultraligero.net/Descargas/Manuales/JPX/4t60.htm With hopes, Cristian |
| cary |
Jun 28 2018, 01:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
Do a Google search for Colin Lamb attorney in Portland Oregon.
He has powered glider with a Porsche Type 4 engine. Years ago he had some enhancements done. Let him know that Cary Kutter sent you. Good Luck ... |
| ConeDodger |
Jun 28 2018, 02:01 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,218 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Aircraft motors tend toward torque over HP. They don't rev very high. Make sure whoever you get to help with this, they know aircraft. In the US, the mechanic must be an Airframe Powerplant Mechanic. Not sure what your French laws on this might be.
| jcd914 |
Jun 28 2018, 02:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The web page you linked here shows a type 1 or type 3 based engine, not a type 4 engine.
914s used the type 4 engine, here are a lot of good people here but there maybe better type 1 or type 3 information in a VW group. I don't know what groups are good or not. There are lots of performance parts for type 1 & type 3 engines and in the VW automotive world 80hp is low. Jim |
| Valy |
Jun 28 2018, 02:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Simplest way would be to change the piston/cylinder diameter to 96mm.
You might want to change compression and camshaft as well. If you need more help, I can connect you to some of my dad old buddies at the airplane factory in Bucharest. They had a full remanufacturing line for aircraft piston engines. There is also an helicopters factory somewhere closer to you. You might find help there as well. |
| thelogo |
Jun 28 2018, 02:37 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Sounds dangerous, you can count me in
A type 4 in a aeroplane? Not really sure why you would go (IMG:style_emoticons/default/wub.gif) this route But just remember the right way to build and install and run the engine = the way you dont die . And a humanoid price ? I always thought everything avaiation was expensive (IMG:style_emoticons/default/pray.gif) |
| ConeDodger |
Jun 28 2018, 02:59 PM
| Mark Henry |
Jun 28 2018, 03:49 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
By the looks of things greatplanes has stopped doing T4 engines. I do know they had some prop hub failures.
As for power aircraft engines are about torque so a longer stroke would be a first consideration. But the crank you have may be modified for a prop mount. LN nickies could be used to up the size and save a bit of weight, but they are not approved. In fact if you tell them it's for an airplane they may say no, so you would have to "wink-wink" not tell them. SDS fuel injection got its start in homebuilt aircraft, they make FI systems for aircraft. Lots of homebuilts using SDS. http://sdsefi.com/ I do know out of car engines they prefer subaru engines for aircraft. None of the options I just gave you are a humaniod price (IMG:style_emoticons/default/wink.gif) |
| Mark Henry |
Jun 28 2018, 03:50 PM
If you click on the OP's link it is a T4 engine, that's a different engine. OP's link http://www.ultraligero.net/Descargas/Manuales/JPX/4t60.htm (IMG:http://www.914world.com/bbs2/uploads_offsite/www.ultraligero.net-26-1530222808.1.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.ultraligero.net-26-1530222854.1.gif) |
| Mark Henry |
Jun 28 2018, 04:03 PM
Is your plane a Robin ATL?
https://en.wikipedia.org/wiki/Robin_ATL (IMG:http://www.914world.com/bbs2/uploads_offsite/upload.wikimedia.org-26-1530223428.1.jpg) |
| 76-914 |
Jun 28 2018, 04:21 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,814 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
It's been done lots of times. The carb will actually be more reliable than the Type 4's DJet or LJet. Hopefully you understand that you will need to plumb some heat from the exhaust to the carb with a diverter box that you can buy or build your own It's been years but I do remember a guy named Ken (maybe Ken Rand) that sold plans for his homebuilt. It was a Type4 turbocharged and quite. He was here in California. You need to use a rev limiter to keep the rpm's below 3400. I don't know the length of your prop but if it is close to 70"+ the tips go supersonic around 3400rpm. I'll try to find some info on it if your interested but I won't be back in the US for a couple of weeks. France has an active Home Built Aircraft community so you should have great resources there as well. Are you a member of the EAA ?(Experimental Aircraft Association) If not you should join. An absolute wealth of info there. (IMG:style_emoticons/default/beerchug.gif)
| 76-914 |
Jun 28 2018, 04:26 PM
Aircraft motors tend toward torque over HP. They don't rev very high. Make sure whoever you get to help with this, they know aircraft. In the US, the mechanic must be an Airframe Powerplant Mechanic. Not sure what your French laws on this might be. In the USA if you build your plane then you hold the "Repairman's Certificate" which never expires and you can do all of your own inspections and work on any part of the plane. Outside of that loophole you do need a licensed A&P, military excluded. |
Lo-Fi Version | Time is now: 26th October 2025 - 04:24 PM |
